suggestion for speaker combinations
While purchasing the speaker,i asked them about the stands along with speakers, they only said it costs nearly 10k.. so only i dint bought. Is it possible to build our own stands?? Where to search in our forum...??
Oh okay. Yes it's totally possible to build your own stands. Search in the diy section of this forum. Google for it, you'll find some pointers there too.
MaSh
Sent from my Redmi Note 3
MaSh
Sure i wil look into that bro..thn for upgration purpose, i need to buy sub or centre speaker first??also 1thing i noticed while hearing is that sound is not very loud.. that is very pleasent to hear..1more doubt is while calibration, the speakers are detected as large. Should i need to change it to small ??
In my opinion always move from one complete system to another complete system. Stereo 2.0 is a complete system. 2.1 is a complete system. Next 5.1 is a complete system. 3.0 or 3.1 is not a complete. Considering that I would suggest get Sub first. Get center and surrounds when you decide to move to a 5.1 system.
The speakers are set to large since you do not have a Sub. Hence all bass frequency would be sent to front speakers. Set them to small once you get the sub.
MaSh
MaSh
Thnx bro.. thn suggest some good sub for the polk marantz combo bro. Do we need to use any voltage stabilizer for the receiver??
What is your budget?
Less than 20k - polk psw110
20-30k - taga sw10, boston acoustics asw250, mission ms200
>30k- polk dsw 550, velodyne impact 10, etc
Sent from my ONEPLUS A3003 using Tapatalk
