Suggestion on stereo setup integration with AVR without preout
manindra.mukherjee
I have an entry level Yamaha AVR which is working fine both for music and movies. However I want to have a dedicated setup only for music since the AVR is just OK in delivering sound output to my liking.The AVR doesnot have any preouts . I want to use LR Sonodyne BS speakers for the stereo.
I was thinking of buying a stereo amp which I could connect / integrate in some way with the existing AVR or setup. I have no option to manually change wire connector everytime I swicth from my stereo amp to AVR and vive versa since the space where the AVR is installed is limited and would be difficult and cumbersome to reach out everytime to swict connection.
Do I have any alternative here ... kindly suggest
You can use the amplifier selecter switch for this purpose.
Search on Amazon or reach out FM @sadik if you ok with DIY .
