Hi Guys,
My current system almost complete for atmos (jbl fronts, klipsch center, klipsch rear, klipsch back, klipsch atmos height speakers onkyo tx nr 686) I have my own DIY passive subwoofer from old days and I want to buy a proper amp for it (in next months Im planning to buy a new active subwoofer -or- a new DIY subwoofer and complete my HT as 7.4.2)
My current subwoofer driver is Kenwood KFC-WF303 (Max (RMS) Output Power 600 Watt - Frequency Response 25 - 800 Hz - Nominal Impedance 4 Ohm Sensitivity 93 dB 12inch)
Im planning to buy a Behringer power amp (because its easy to find in my area) and I found following models for my budget :
- Behringer KM 750
- Behringer NX 1000 D
What you think guys, which one will be correct amp for my subwoofer ? If KM750 is also ok it will be a cheaper solution for me ? Do you think I need an amp with DSP or is it not necessary ?
Lastly I want to ask your opinions : which way is better ; buying 2 channel amp and use one channel for current passive subwoofer, and use other channel for a new DIY subwoofer instead of buying an active subwoofer ? which one will be a better/cheaper solution?
Im open for other suggestions!
Thanx!
- Behringer KM 750
Thanx!
