After the auto calibration you have to manually tweak the settings. Use a measuring tape nd measure each speaker distances from your listening position. Play a long action scene repeatedly nd test different settings. It will definitely take some time for u to get the right settings for ur room. Read the user manual it will clearly explain the settingsO did tried, but didnt like the auto calibration settings. So ask..
Also what is speaker distance should be put?
Which program is best suited, for sd tv, hd tv, movie, bluetooth..
Ok... ThanksAfter the auto calibration you have to manually tweak the settings. Use a measuring tape nd measure each speaker distances from your listening position. Play a long action scene repeatedly nd test different settings. It will definitely take some time for u to get the right settings for ur room. Read the user manual it will clearly explain the settings
Hi @Manishpatel722 I am new to this forum...I also getting a similar deal for YHT 3072...Can you please update on how your system turned out ....is it ok to buy this system from olx without bill. Will appreciate any suggestions or help you can provide on this ...thanksHi,
Thru olx found one seller selling yamaha 3072 with speakers.. Selling with rs 33k pack piece but without bill, Indian version..
Need help should i go with it or not?
Without bill is an issue..
I am going to see personally tomorrow.. (what things should i check?)
Is this worth deal or should i let it go
i heard the demo and purchased also from a store. They are authorised store for yamaha in chennai, so do not buy in OLX it may be reworked (could have problem made ready, perhaps the owner wants to get rid of) always buy brand new with the people who are authorisedThanks for reply... I will see personally n then post..
Any reviews on yamaha 3072??
pro logic mode is the pest program mode for movies, where you get dialog from the center speakers aloneWhat is best program mode for movie? Music? Tv serials? What r calibration values?
Also found that when full volume on amplifier (when no input music is playing) i can here eco (erroring echo) in all speakers?
Any instructions from where to setup n get use tp with it
but yamaha yht-3072 not equal to yht-1840 since it does not have active subwoofer and usp port in it. see the specsI used yht299 for 3 years. The specs of the speakers nd subwoofer that came along with yht 299 are almost similar to the speakers and sub provided with 3072 htib. For a small room it will be good. It won’t be good for medium to big size rooms. With proper speaker nd subwoofer calibration it will do a decent job. Mine was a 12*14 room and after a year I changed the center Chanel speaker nd sub which improved the overall performance. The more you increase the volume u loose the quality in sound as the small speakers nd sub tend to strain. So the entry level Yamaha HT is definitely a wonderful deal for a small room. In a small room u can keep less volume nd yet hear everything clearly as the speakers wil be placed well near you. The further they are kept the more volume u need to increase which causes the speaker nd sub to loose the sound quality. This is my honest experience with the package. Now I sold it to my friend nd he has placed it in a small room nd it sounds good nd he also enjoys it.
i heard the demo and purchased also from a store. they are authorised store for yamaha in chennai, so do not buy in OLX it may be reworked (could have problem made ready, perhaps the owner wants to get rid of) always buy brand new with the people who are authorised
it goes well with Yamaha tower speakers of ns 8390 also with taga harmony 607 package than the default package nsp40
Yht 3072 is a better model for sure.Also Would like to correct my room dimensions. It’s 10*11 and not 12*14but yamaha yht-3072 not equal to yht-1840 since it does not have active subwoofer and usp port in it. see the specs
One of the worst Yamaha showroom, better to avoid it. The owner will speak to you like an unwanted guest.i heard the demo and purchased also from this store..............here i am sharing the link..............they are authorised store for yamaha in chennai, so do not buy in OLX it may be reworked (could have problem made ready, perhaps the owner wants to get rid of) always buy brand new with the people who are authorised
Yamaha YHT-3072 | Best Home Theater Amplifier |Av Receiver
Yamaha YHT-3072 is the basic amplifier with Hdmi input 4 numbers with optical input and pre out subwoofer, 4K video at 60 frames/second pass-through,electronicbazaru.com
