SVS PB-1000 or SVS SB12-NSD for 12 x 12 x 10 room
Hatredcopter
Philippines
Looking for a new subwoofer and I've narrowed it down to just 2 subs now:
SVS PB-1000 (27,000 php)
SVS SB12-NSD (31,000 php)
Room:12 x 12 x 10
So far these are what I've found available locally. Considering the price which of these would be best? Looking for that home theater "feel" but I use it in music and movies.
Current setup:
Receiver: Wharfedale AVR 5110
Front: Wharfedale Diamond 10.1
Center: Wharfedale Diamond 9.CS
Rear: Wharfedale WH-DFS
Sub: Wharfedale Powercube SPC-10 - Defective
I might be able to add a 2nd subwoofer (Wharfedale SPC-10) once I have it repaired.
Amongst these, I would prefer PB1000. :)
For HT/music use, I would always prefer a Ported sub at this price range. If purpose is "only" music then I'll go for a sealed.
Room:12 x 12 x 10
Current setup:
If you can find and add an other Wharfedale SPC-10, would be good.. It would make dual, identical subs..
You can fix the existing sub and find another Wharfedale Powercube SPC-1.
The above will do wonders in your setup. rather than going with a single SVS pb 1000.
If its between svs pb 1000 and NSD 12, then I would choose the NSD 12 for the better driver and power.
Thanks for the suggestions everyone. I auditioned both pb-1000 and sb12-nsd today and I went with the sb12-nsd due to the better performance in music in my opinion.
Wont it be an overkill to use 2 subs in a 12x12 room?
Nope.. Benefit of dual subs is producing even bass across the room..
Most articles on the net, suggest dual subs regardless of room size..
I have a slightly wider room than the OP, 14 x 11 and run dual subs (Front corners). Bass in the room is defnetly good than what i have heard before without sub's..
Congratulations. How much is the cost of the sb12?
It cost me 31,000 php, 2 thousand more than the PB-1000 at 29,000 php.
@elangoas
I have read the same things about 2 sub setup. But that is long down the road for me. maybe in the next year. for now my next in line is to upgrade my cheap receiver.
