SVS Subwoofer Owners Thread
Default setting is 80 hz. Does 100 - 120 or more hz can damage the sub? just curious.
Drivers are usually not damaged just by a singular frequency but rather the duration and amplitude of said frequency. The usual methods of damage are thermal and mechanical. Mechanical usually occurs the lower in frequency you go or below/around tune. Thermal occurs more with duration, particularly at impedance minimum, which varies by design.
In a nutshell, the crossover (if that's what your asking about) can be used at 100-120Hz without damage.
Any first hand user reviews on the sb3000. Has it got good mid bass? Is it equally good for movies and music. Had the pb 2000 earlier. Didn't like it for music.
20% off on an Svs is a gr8 deal,go for it..
Thanks on giving me another perspective (%). I am curious if a price of 1.08lakh an inflated price due to Covid or is this a regular price.
I am looking at PB2000 Pro for both Music and Movies. Any idea whether PB2000 Pro is also not good for music?
Setting the Subs crosswover above 80hz wont damage the sub but still it is not recommended because it will cause Subwoofer Localization, meaning that you can tell where the low frequency is coming from, which will defeat the purpose of a subwoofer and have adverse effect on the sound quality.
Thanks, good analysis.
I hope it is not late. If you have a large space go for PB2000 Pro else SB2000 Pro is good. I have purchased PB2000 Pro and it's more noisy (noisy i mean very powerful) I guess.
With the rates & deals around many from my friend circle are planning to update to the Pro series barely even using their existing PB / SB subs for a year. It seems the Upgrade bug is biting well for some;)
THX recommended cut off frequency for subwoofer is 80Hz (It's not the default setting). You can try 100 or 120 HZ and check for any improvements in vocals. Especially if you feel the male voice is fuller with a higher cut off then you can settle for it. It all depends on your equipment.
Nope, I upgraded because after serving me for 5 years my Velodyne EQMax12 left me for heavenly abode. Plate burnt up. So, instead of repairing it, my dealer suggested to for a new one and i got a discount too.
May I know your room dimensions ?
It is 18*12 plus 28*12 open space. Living room and Dinning room combined. I installed in Living room.
05NLJEKN2ec6nf_j63X-y0n9--kFBa6NwponLsAq20eByPtsh67-XUa3E1bjXfwV1HsGVzCFWb6qyBaAgy8C-6Dg_0QvAb8CAiGGr3sVp6Zz0K-5L_b5jPbamtvqEDqeSvIJbTR_wYlZeeFVm4h82BbBZeRMXOO-5FNsG6w0Ox-KbShVZxJRAivzRXb8dx_HwoPTGYx9yGdoes3QcBTjLIpdY8Su7bbH3NkYLnq1CbZScNUE8WeJ2MAWaLuBmPOx7eFjUlRjJoD0oxs0QyytNjBtqcNpCCikX6fSGMM_ZI0ZiYnRJf1ctm8AvYGlIOOMB-drmp_DwATvtqiBD7KR4YuFpvQ_7qecY7ToekbkwwHUZ8_LzQMKss-hiedyyVIvKwC44gQGW09DE5ZbHS8LTmw4rANDkxs1iCVeSOpsenNWYcAxnGk_ueCHJ0KsipHjcv9u4l7AhciLdJ3r0FLMQiQx2kIgEYSWNMx8RychBEgYij4fdiYyfxKJOnD80XjodKknlR1HQx5CK1lapo2VtwhYFWzsLa9rGIEIheUpnOYz3rbWJfzd_l5GPGPdurunZKQk0ECp7SGxg0Dafdvxf6REuLRfLYQTkAjbXpov-lo114Ioxd8T7oNy-rR_XAcLAnUck2ttxTld-e5jFfXpwbSgVbOFzoRLUFSmpHsym3ZVifXYqoEP2YeUUhcXYz5fOEghvCy48etVziHfeBvNEhm3=w708-h943-no
Gu2cbVCqjqSwtJV_kRU5KJwzx2unHNpsBx5pLP4nP1XHRpJmaVqC5wASDWTjDGtkxiHH3IRApUjEOISf-zXrixIxw4SO7Zh1ebIfIQ-xqPnAgyEGUcXGXFGNVw7WABIEJWiRIu73A6vC-tSaLj2-zY8h_0flnbgiyDl4iEjJRotbcNCUGFw6aLepAtdPhxGuq-J6vZ_T_hKCAmf9pVJrxghi7IbBL5xXS_7ipV7ZsI60iAzWeooZLtkb5MF_mzbFZVklPJ1_-UQmbu4N2gY5oRKrVpXRnSLhY7mUXlllhsxkS_MEuN7J6iv9nyLzCi-wUoOzWnY6-UWFU97dxL5F2FmGgRUvbWGb-hBldUscZ7xqaVHsfWblcvwGyFGKCPTZxKKwmjkURLbuerFO7q0dlcYtks5KJZyU2lEW0RXlPweZBqhsrKVLzxc8fwNlq9IMEVM6nuzapnY10JIPhQqF-kkFK0Wi0xXvq6VoYxxB1Q4Y2hvsVqBMymRLGyHH8E1n02JP5I8eAOH86dXlnnzzlAgPQL2q_sjvi3sNUkvXp_UFXdiB7Vwlzq-Y3FidJVPd_WBL0OZ_vFXI_OGeH1YXI1Bt0dK6JxkyXuT1neqjBpVv_2kfxqAQosNMQO0aH04ww3xJKUynn44HFJkzqG3tAk3quN_kD4LEZxLHA0h0uQcSrbdbozBU8g10yIMThwxpyiNkZCjhtQDFCJzYpGhmemWw=w1258-h943-no
PPItYrTnfvmhZ0FDOPFkkxQ3xeH3sGJTEbStZqSYINh-ZwbaQKgumh3O-gb1qRAwU77Wk4cg5pj4DL-ZnMCML8pqiAO70EGY0IIM4pC3wV42dYMoWNCCsqidUZqQlyb1QME9OHd8xjnfbddr3b4hQT0oi_xL-WpvTEzuRHQ8SzfoGO_ANLOrET6Qs_1FmfdAELrDKLRdOO1hZOMNZTUzTaCPmuoIxl_v4RIa9RTmP_BZp7yWP__PzHBUXRYk63-B3eDuv-1pSi--hddljyo5NPjdJprjjysF0W5yZf_gvJ1DYszZ7yYo-IbRNLmKH_jJRvDYH579PzgnyPhY9lZYvMiXnsuJiOyhVDF59TLc3es9CPouQrrBpxSmgWdvGxPPy1Vt13nlZyfyh0oWPPTM5uwtu-x3NjDGz4frf7rR-M0Az5WHcZhYj5so2koR9INiZ8tybXM04t9uXPtJWJKyfMAgaa1CViXRrbRrqkDwt3ZXoikrJzlQ8jCgzIDabC9o0eWp0QqCluwF6qDzUgxxHTC2oxaf0x8wKPjgpanDj6tJ4Z1kCIV35JTYiMQ_vcIcBTgprPUOu09oKA4b9KmSRyqtgWHSckIHjvsao_LXr5Z8Ga5jzuCZJxH2F-HnvbCWAOLHHsnJ5_YJ_JURtZgDRONNOf-FhXSUys4SdCzWlLA5lRZnfYY1Dk3Y9Yg28hZ4epe8ac_VLElbol-6_9zs204y=w1258-h943-no
Makes sense! Congrats on your purchase...so how much discount is running these days?
hey SB1000 (non pro) owners, do you mind telling me your sub volume and room size?
My room is 20x10 and my dial is at about 1-2pm (~65-70%) (Sub level on the AVR is set to 0db), does this sound normal?
For close to 1800-2000 Cubic feet probably SB 1000 would be pushed too hard to produce a good SPL, it may even reach clipping stage unless your average listening master volume is no more than 60db.
With 1-2 pm of sub gain the gain on AVR should be kept to -4db in my experience otherwise it would be too much pushing the sub.
What is the crossover by the way?
What's the current best price of SVS16 ultra? Need this in Kolkata. Any place in Kolkata where I can auditon this?
Hey, fellow SVS owners. I have been using a PB-1000 for the last 4 years. I really like it. I have been looking to get one more for the longest time but to no avail. The MSRP has shot up through the roof and into the sky and it seems like a distant dream for me now. Is anyone looking to part with a PB-1000 in here?
