Narayana
Hi friends today i received subwoofer Tagaharmony platinum tsw V3 10 inches I purchased from next hifi store RS 26000 performance of subwoofer excellent no destortion ,no humming sound
Excellent performance no destortion,no humming sound right now I checked only songs FLAC songs playing very well in my Denon 1500h iam using Tagaharmony 606 V3 with platinum SW 10 V3 my friend testing my even full volume no destortion very happy of the performance of subwooferbut still you should have asked for, anyways let us know your take on Sw10v3 once you receive it share your review, i'll also plan for one if it is really good,
Hi Guys, Today I ordered Taga Harmony TAV606-SE from next hifi. Waiting for delivery. I don't have an AVR yet. Planning to buy a Pioneer VSX-LX302 or VSX-1131
Thanks and Sure, I will update my review. I am a bit confused which AVR to take. Currently considering lx302 and 1131. Any advice is appreciatedCongrats. Please do give your review on the same once you are all set.
Hi,Thanks and Sure, I will update my review. I am a bit confused which AVR to take. Currently considering lx302 and 1131. Any advice is appreciated
Not sure about LX302; but i have been using VSX 1131 with taga 606 since last 2 years. Its value for money. You won't regret. But, LX302 is also dolby vision compatible. If you plan to make use of dolby vision feature; then go for LX302.
Thanks @revolty. Last Friday I went to purchase AVR and lx302 was not available. They had lx303 though but it was too expensive to my pocket. So I picked up vsx-933. Now my HT setup is complete and enjoying the surround sound![]()
I purchased it from Hifi Gallery, Parrys Corner, Chennai. I bought it for Rs. 34.5kCongrats on your purchase of vsx933, what was the price and where did you buy from?, please share your experience with vsx-933 and how well it blends with the Taga 606se when compared to your previous 1131?
How is the power of the AVR vsx-933 does it handle 606se well or you think it is bit low powered AVR?I purchased it from Hifi Gallery, Parrys Corner, Chennai. I bought it for Rs. 34.5k
This is my first AVR and first 5.0 speaker system. I was considering to buy 1131 but it was not available. The experience so far is very good. When I set it up initially with auto mcacc it was not mind blowing experience. Later I changed speaker configuration and it sounds great now.
Lot of people feel that the low freq effects of tav606-SE is quite enough. There is certain amount of bass from the speakers when I set the cross over to 80Hz. But it can never give you the satisfaction of a proper sub.
Congrats on your purchase. BTW are you using a single LFE cable or a Y cable for connecting the sub? Many people say that with a Y cable the gain will be higher. I actually tried that but the sub was sounding a bit boomy, so switched back to a single LFE cable.Excellent performance no destortion,no humming sound right now I checked only songs FLAC songs playing very well in my Denon 1500h iam using Tagaharmony 606 V3 with platinum SW 10 V3 my friend testing my even full volume no destortion very happy of the performance of subwoofer
Hi iam using y cableCongrats on your purchase. BTW are you using a single LFE cable or a Y cable for connecting the sub? Many people say that with a Y cable the gain will be higher. I actually tried that but the sub was sounding a bit boomy, so switched back to a single LFE cable.
Glad u got your sub back to normal...Enjoy / Cheers.Collected the subwoofer from service center.. The weird noise is gone.. The technician said it was due to faulty high voltage capacitor..
Now works like charm..
Since this is my first active subwoofer, I'm still trying to understand the optimal settings for the subwoofer. I am confused with the cross-over value that needs to be set on the AVR and on the subwoofer. It would be great help if FMs here could provide me inputs on this.
