TECHNCIS CD PLAYER - REPLACEMENT LENS
viji
Tuticorin
I have using the techncis SL-PG370A cd player .... now want to RE 1100Z CDM 12.1 optical lens...
In my CD player there is Philips CDM 12 as the drive mechanism. Few years back I got lense replaced ( as DIY). I got the part from a Singapore seller on EBay. That works well till now.
Before that I got lense mechanism from a shop in Mumbai, that did not work and labour to replace was wasted. So got from a Singapore seller on eBay.
Thank you sir
Better to buy from sellers with good positive feedback, do not look at price only. As there are many sellers passing on defective lense mechanisms: the thing is you loose lot of labour in replacement and then find that it doesn’t work. Just my experience
Good luck
