SoumyaRajagopalan
Please recommend a washing detergent and how many drops.Reviving this old thread.
9 years now since I have been using the DIY record cleaning solution of Distilled Water 80%, IPA 20% with a few drops of washing detergent and it works like a charm. For Records which need deep cleaning, I use a soft tooth brush and it does the job very well indeed.
Best part now, you get everything on amazon now Distilled Water + IPA + Detergent + Micro Fibre Cloth and Application Pads !
Do you recommend a brush before or after the cleaning? Please recommend a good brush from Amazon.
