The Mighty SET 845
heliumflight
delhi
People say that once you have tried tubes, there is no going back to solid state. I would like to add that if you love music, once you have tried single ended triode amps, there's no going back to SS or push-pull amps.
The beauty of the 2A3 tube is in the glorious midrange that's where the music lives and breathes. But with the 845 you get the same benefits of the 2A3 but with a bigger soundstage. Yeah it might not to do thunderous bass or the absolutely crystal sounding highs, but what you loose in the extremes of the spectrum you gain BIG TIME in the midrange. That is where 80% of the music lives in! When I used to listen to SS amps most of the time I was trying to anlayse and dissect the music. Whereas with the 845 it will involve you into the music and you will drift into it with realising that you are tapping your toes and shaking your head.
Now on to the sound. The sound of these amps is incredible. I can only descibe the sound as wholly organic. I found that I don't listen to music like I used to. I now hear the whole band palying as one as opposed to various guys as individuals playing music together. The tone is much more life like with a texture that you can almost feel. The low level detail retrieval is fantasic. The 845 is very extended on top without any hint of harshness. Cymbals ring true and the decay is spooky. Notes just fade to black. Guitar and piano chords are vivid as you not only hear the chord but you hear all of its harmonic components. These amps, and I would imagine other SET amps, bring out harmonics that you don't realize are missing until you hear it properly done. I don't jump around and change discs like I used to as the music is much more captivating. I also don't listen in fragments I know people debate which is the better tube, the 2A3, the 300B or the 845 but for my needs the 845 was the way to go. It is a very dynamic tube which retains all of the harmonic richness that is often associated with the 300B, while providing plenty of headroom and dynamic drive and low end control.
helium
Hi Sumant,
Congrats on your new amp.Glad you like it.
How does the new amp drive the B&W's?
Please give us some details like what tubes are used,power output ,type of rectification SS/tube.
Rajiv
Hi Sumant,
Rajiv
Thank you!
Enjoy the clarity now!
Audio tubes
Output tubes- Shuguang 845
Input tubes- 5687
Driver tubes- 6v6
Tube rectified
Main rectifier Parallel 5V4G
Input rectifier- 5W4
Total tubes= 8 nos.
helium
hey helium is it you in photo?
also how lyrita sounds with normal source ( i mean DVD+ Byrestford)?
Congrats Heliumflight,
Glad to know you've finally found what you were looking for. :)
regards
Anm,
You can't mix tube types on an amp, only roll other brands of one type. That's a custom build by the man in the pic for the man not in the pic :)
edit: well at least unless the amp is built to accept certain types of tubes. Some amps have switches to roll out different output tubes too which one would normally not have the option of doing.
regards
regards
regards
Thanks Steven.
This toy does all the things what the 2A3 does and more.... It basically does everything bigger.
The tuubes are almost like 10" high and 2" wide. I lost a beat once I saw it!;)
helium
Thanks Steven.
helium
Haha, yeah they're monsters those tubes...The power should be more than enough for you now. ;) So started saving for a pair of NOS 845s :p
regards
