sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,239
- Points
- 113
It is very clear to me that NAS needs a bit deeper technical skill set than just using a computer or a bluray player. And that is / has been exactly my point.
I request you to suggest the OP based on your expertise whether he will get benefit with using a NAS in his case.
If the requirement is only to aggregate the data, would an external HD with the needed capacity (DAS) will suffice or is there any added benefits by putting the Storage on a Network (NAS)? As I have been suggesting since the beginning that in my use case (possible for a regular average user use case) a DAS might suffice but I really appreciate if you could write few lines about this as it can help me as well as others who might not have full understanding of the topic.
My recommendation to a layman for a NAS would be...
1. The user has at least more than 5TB of data
2. The user has his/her data scattered all across different HDD (internal/external), or devices, pendrives, SD cards ...etc etc
3. User would like to centralise all of his data in one location for easy access, better manageability and getting it organised.
4. a 24x7 running DLNA Media Server.
5. a 24x7 running file server, with protocols like webdav and sftp
6. a 24x7 print server (if needed)
To an advance user ....
1. All of the above ... PLUS ...
2. Better data security and redundancy
3. Global access of his/her data (from Internet and mobile)
4. Integration with directory services (like in small business, eg internet parlor, small office ...etc)
5. VPN server/client
6. Surveillance
7. Own cloud services
8. Own personal mail server
9. Tools for small business, like need for a database, phpBB Bulletin boards or opening an online merchant shop ....etc etc
The OP qualifies for the first 4 points at least ....
Also good to know that these NAS device do not fail. Given the world we live in of planned obsolescence, it is good that these devices are built to last. Fortunately I did not experience dying of electronics personally but heard from friends of the stories of HDs TVs and all sort of electronics failing I got a bit skeptical about NAS failure as it is akin to put all valuables in one safety box and loosing the key.
There is difference between TV consumer electronics and NAS dude ...
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
