Toshiba 39P 2305 or Samsung EH5000
^ did. 3 times mute on remote. Again mute on remote and hold. Then press menu on panel and left both button.
Were you able to check the usage hours? If so pls tell me how did you navigate to the option. I am going to buy the 39L3300 model and want to check usage in the showroom itself. So would like to go prepared for that. Please help me.
Hello,
I'm inclined to buy 39" model as a gift to my father, who's a big fan of Cricket.
I've a question: how much Power it consumes? Above 100W?
My parents use one 1100 VA inverter so the Power value is important to know.
Thank you
^ I am unable to go to the other options.
Can you please try as below
# Turn the TV on.
# Press the {MUTE} button three times on the remote.
# Press the {MUTE} button again on the remote and hold.
# Then press the {MENU} button on the TV's front panel.
# Release both buttons
# There should be a letter "S" on the upper right of the screen.
# Press the {MENU} button on the TV's front panel again.
# You are now in Service Menu.
# Use the {CH+} or {CH-} buttons to select the item.
# Use the {VOL+} and {VOL -} buttons to adjust the value.
# Turn the set off to exit the Service Menu.
Important Note: Please don't adjust any values that you are not sure of that can potentially affect the usability of the TV
Old thread to bump but I am little amused here as when I am trying to connect my 2.1 Ch audio to the TV, I have to manually control the audio from the speakers and the volume button on TV remote does not work.
I have read that there are variable audio out and fixed variable audio out. I believe I have connected to the fixed audio out but is there any variable audio out from this TV?
Yes, its wall mounted. Done by Toshiba engineers only. I am afraid I won't be able to share the pic as I can't remove the LED from the wall.
The bracket has 4 screws which are fixed in the wall.
