Kana711104
The monster is getting a master tablet.Rejuvenating with V4H.
Dual mono power amp initiated. I need a crane.View attachment 43694View attachment 43695View attachment 43696
Wonderful build sir . Shaan sir can you help me with the finished amp pcbs (2 nos.) and power supply pleasePreviously on peeceebee: A four channel standalone amp based on V4. This was completed in Dec 2019.
View attachment 43697View attachment 43698
Thought this might interest people.
The PeeCeeBee preamp's final prototype showing some bold traces.![]()
Looks very interesting, can that be done with a potentiometer instead of the variable resistor? Essentially the same thing right?
Hmmmm, tasty! Distortion on demand, I'm definitely interested in one of those!
Well coming from Shaan it must be good, to a novice like me, its all greek and latin. I will just wait for a video with a sample music recording.
Shaan, please try to incorporate a remote into the preamp. Not everyone will want to get up to adjust the volume.
MaSh
Thanks, will upload some samples shortly.
Remote volume and selector kits of various qualities are available. Those are not part of the main preamp. There will be no digital control systems on the same board as the preamp. It will have its own power supply on board however.
That said, say you buy a complete preamp from me installed in a cabinet with multiple inputs. Of course I will install one of those remote motorized volume control kits inside.
Yes I am aware of those kits and the issue is exactly what you mentioned, varying quality.
MaSh
Yes, but is it very difficult to integrate the perfectly matching remote controlled volume control into a preamp?Solution is easy. Get the good ones, with Alps BlueVelvet pots.![]()
MaSh
Why is it difficult?Yes, but is it very difficult to integrate the perfectly matching remote controlled volume control into a preamp?
MaSh
Preamp update:
Testing different THD level at varying output levels.
YouTube Link-> THD vs. LEVEL
THD control is now confined to a resistance rage of 10K. This potentiometer will be additional to the volume potentiometer. Next update will report THD vs Load impedance, clipping performance and listening tests.
Stay tuned for more.
