Triple Boost Stabiliser for AC.. Good or bad?
Subcenter2009
Chennai
Dear friends,
Because my One and a half ton Voltas window A/C was not working properly with a Double Boost Stabiliser by Premier , ( It kept tripping every half minute) despite keeping the thermostat at minimum, I recently purchased and installed a 4 KVA Triple boost stabiliser also made by Premier. Now, the A/C works well but the A/C fan seems to be rotating very fast when the compressor is not on and makes a humming sound similar to ceiling fans when the inverter is on.. Hence, I am wondering whether this kind of Triple Boost stabiliser is good or bad for the A/C.. The stabiliser also gets hot if the A/C runs for a while at a low temperature setting without cutting off.
I wonder if it is safe to use this Triple boost when the input voltage is ever in the normal working range ( 220 - 240 volts). in less hot days.
I am unable to bear the Chennai heat and feel tired and very uneasy if the A/C does not work during peak summer days.
The input voltage on most summer days is around 180 Volts.
Please share your views about Triple boost stabilisers.
Yours,
Subcenter2009:cool:
When voltage drops, the current draw increases proportionately to keep the appliance running coz Voltage x Current = Power (Wattage). If current draw exceeds certain threshold level, the MCB trips to avoid overheating of the wire which could even result in fire.
Getting a triple boost stab means forcing the system to stay alive by drawing more current to compensate for low voltage, so you have to check couple of things:
  1. Wiring from the mains to the AC should be thick enough to withstand the increased amount of current at lowest voltage.
  2. Install an MCB of a safe limit.
If these are fine, then you may have to get the AC checked up.
Uday
