I have been trying to follow several of your posts now Jeff..it's always difficult to follow and understand as you write in a stream of consciousness style...flowing from one to another and to another so it's not easy to lockdown your final suggestion.
The one thing i understand clearly and see consistently coming from your posts is starting with a high efficiency speaker, preferably 100db efficient or more. Beyond that what you want to convey on tube amp is NEVER clear. It's like you knot yourself into a pretzel after saying high efficiency speakers!!
Often it's clear what you dont like...like 300b or mac275.. but what you intend to say on what's your recommendation on tube amp probably will remain with you cause you don't seem capable of plain simple speak on the topic.
Agreed. LOL, very good !!!!
The amp, in 2023, is easy.
No more than 10 Watts wanted.
Single Ended amplifier.
Output tube can be either triode ( JJ 2A3 ) or beam power tube / pentode. ( cheap 6AQ5/ better 6005, KT-88, KT-150 ).
Two Stages only, total gain, when both tubes' mus are multiplied, equals about 400 Xs.
Directly Coupled only.
L.S.E.S. Power Supply only. Two 6 ohms or less chokes ( Hammond 159ZA will do ).
Dual 5U4GB rectification.
Softone RW-20 Output XFR.
Proper wiring throughout.
PM me if you need any help.
Of my many posts, last few years, start with this thread :
New Design, SE 6005 Directly Coupled Audio Amplifier
This is a current design and build project, a DIY hobby of mine for many years. It uses a 6005 FINALS tube, which has a 10 Watt (correction - 12 Watt) plate dissipation, and was introduced in the 1950s. Used in car radios and TVs as the FINAL stage, in the USA and in Russia ( an equivalent )...
and realize, the thread's amp was for horn loaded Lowthers ( 104 dB ). Amp is NOT powerful enough with a single 6005, two or three 6005s in parallel are fine as a solution for most speakers that are efficient.
Jeff
