mahiruha,
what i'd strongly recommend is that you stick with the lyrita phonostage cos you haven't really explored it or set it up to match your cart. if you do this and still don't like the sound then you can explore other options.
step 1: you need to install a step up transformer in it. so you need to do some research and figure out which trans will suit your cart best. viren could help you with this. you can then import the relevant trans and have viren fit it in.
step 2: the tweaking with resistors you're talking about, viren can install a resistor in the phonoamp itself so you can put in different resistors to change loading and thus experiment. from the equation in the SUT page on analogdept.com you can feed in resistor figure and find out if it'll be a good match. again viren would be able to guide you on this and supply the resistors also am guessing. i have got this option installed so i can swap out the resistor if i choose to change carts later on. highly flexible and customisable loading!
i'd recommend against putting in resistors and listening. rather a more long term and better approach would be to figure out the exact resistor/step up trans required and get that one installed so your cart performs optimally. when you've done this and still don't like the sound then perhaps your tastes would be better suited with another family of carts. no point forcing a cart to sound like something its not and the world of carts is huge to explore there will be a 'perfect' one for you
you could sell the cart easily on audiogon and get another one, but do set resistors by science for the cart you're using
step 3: do not dismiss the phonostage without the telefunkens. the tubes you're currently using are no match for these at all.
all in all, optimise your current set up before buying something new. you've got a fantastic set up now really don't need anything else for a while at least!
by the way how did you get the phono load to 1k ohm? just with the resistor and no step up transformer?
regards
edit: if you want a switch for different loads instead of switching out resistors am sure viren could do that too in your current amp.
regards
