My fronts are at +9db( range is -12 to +12) with centre being +11db. So i really dont have muc room left here. And what do you really mean by Dsp settings?
Wow thats really high and does not sound right. Are these numbers set by the Auto Setup? Center at +11 is a Red Flag right away.
Thanks Mash for your support.
See initialy u asked me to get a budget sub. I wanted to ask you when u say budget then what does basically budget mean. Coz i can see the companies which specialise in subs their sub usually costs around 50 60k which is quite high and definitely nit budget for me. With rti's which sub do you really suggest? Like any good sugestions..
I have polk audio csi a4 as my center. It is set to small with crossover at 80. And i dont feel space to be an issue, it hs plenty.
Well you are right. By budget, I mean, get the best one you can in your budget. A great place to check is OLX, Hifiads, and the For Sale section in this forum. Great deals come up once in a while. I am also looking to upgrade my Sub.
MaSh
