Akshit2111
Well that explains it. The TV is degrading the sound, possibly downmixing to 2.0 and then the AVR needs more gain on it to produce audible sound. Are you getting dolby digital+ displayed on AVR while playing netflix? How is the TV audio connected to AVR?
I think you mentioned about bluetooth sounding better, probably because it is natively 2.0, so gain required is less on part of AVR.
Also i initially purchased amazon kindle stick and connected it directly to my Avr.. but then also i used to feel audio performance issues. I called up amazon and they told to connect it to tv directy for the kind of audio problem i ws facing( i found this to be baseless) but then i upgraded my tv returned my amazon stick and till date have the same issue( bluetooth sounding much better compared to netflix youtube amazon prime).
