Used HTS For 6K-10K INR
ManikandanM2210
Bangalore, Karnataka, India
Der fellow AVphiles.
I'm looking for a used Home theater system for around 6K-10K INR.
I know it's too low for anything of a great quality or even good. But that's all I can afford. And I want it for my kid so that she can enjoy listening to Bach, Mozart, Hariprasad n Shiv Kumar Sharma :)
M
Why don't you look for an integrated amp? The sound will be better and you'll find various decent options.
M
In that budget I would suggest a Pre worshipped Sony htib. I think new ones start at around 12k. You would need to check on the input options to suit your requirement.
MaSh
If you want your daughter to be properly introduced to music, get a stereo amp, a pair of stand mounters, a good source and you are golden to go for your daughter!
Trust me, it is the best way to introduce her to good music.
