It's in the retrieval of micro detail, and the finer nuances in music, that tubes shine over solid state.
Now let's see what are the micro detail and finer nuances in music. At the outset, let me just say: although drama, however subtle, is a part of music, it is only a minor part of music. Music is like a painting where the colors are notes, and their combinations make musical pieces. Take an example: In North Indian presentation of Indian classical music, in Raga Todi one does a sliding (i.e. meend) combination S r g r S (r is komal rishav, g is komal gandhar). In Raga Bhairav one does a similar combination G M r S (with M r S in sliding, touching also the note G). Now with well trained musicians, there may be a difference as follows: in Bhairav in descending pattern one does make a temporary stop at r and then goes to S, while in Todi the descending movement will end at S without any stop at r. This is what I could call an example of the finer points of at least the renditions in Raga Bhairav and Todi. One may call it finer nuances or whatever, but we need to understand what it is. Very often, because of lack of musical appreciation, we may focus on the things which are not important for music: for example, how Zakir Hussain's hair is bouncing all around while he improvises a difficult pattern on the tabla, or how dazzling is the sarod looking and how the fingers are going up and down the sitar (I can give a few hundred audible examples which have nothing to do with music).
I am sorry to prolong the above discussion, but I do not want to encourage a discussion based on vague concepts. If you say a certain amp brings out the finer nuances that no other amps can, then obviously we need to understand what these nuances are, if we are discussing something concrete or are trying to hide our lack of understanding both in music and in amps in some fudge factors.
If measurements were a true indicator of sound reproduction, we would have had perfect amplifiers ages ago.
I fully agree. I have expressed myself a few times in this forum on this, most recently in a thread called "Amplifier Burn-in" in the "Introductions" section. But if this is oversimplification, so is yours, based on an undefined (and most likely an ill-conceived) notion of the so-called "nuances".
Let the master, Nelson Pass, speak himself:
"Most interesting are the full-range high-efficiency drivers that deliver the goods with only a watt or so. Its a big design challenge to produce a good sounding full-range acoustic transducer with 100 dB/watt efficiency. When it is properly achieved, you get a wealth of detail, exceptional dynamic range, and a sense of musical liveness that you dont often hear elsewhere.
Tube amplifiers seem to bring out the best in such drivers. They have more bottom end and, a warmer, mellower mid and upper mid-range, and often more top octave. By comparison, the best solid-state amplifiers make them sound more like transistor radios - less bottom and an occasionally strident upper midrange. If you are a solid-state kind of guy (like me) you start wondering how that could be, and if you are a tube aficionado, you smirk and say, I told you so. The solid-state guy probably starts fixing the response with a parametric equalizer, and the tube guy enjoys his music with a nice glass of wine.
A few things about the quote above.
1) I do not see anything on SET and PP, this is important because I thought the discussion was on unquestionable supremacy of SET amps over everything else because they produced the "nuances" better.
2) It is safe to assume that the master is talking about money-no-bar kind of solutions. The discussion here in the backdrop of theVortex's thread within a limited budget is obviously very different.
3) I must say, the quote is a very carefully chosen one and I complement you for that. Although on a first quick read, it seems that the master is actually denouncing SS amps and having high praise only for the tube amps, please go back and read it carefully through. Then you discover that he is actually talking about the full range speakers which, when made nicely, sound very well with tube amps, on the other hand they (i.e., the full range speakers) sound quite bad with SS amps. He says nothing about a tube amp and a SS amp themselves. It's actually a commentary on the response of the full range speakers as driven by SS and tube amps.
Regards.
