VU TV owners thread
Bought VU 49SU131_1 on March 2021 for 47K. within couple of months had to replace the unit due to display issue. TV is just ok for regular DTH connection. recently purchased netflix subscription. When I open the native NF app in the TV, videos are too dark. Video tag says HDR. But this model doesn't support HDR. some videos are playing in 4K resolution but they are dark too which makes unable to watch. Is there any solution. can someone please help? any setting I am missing.
Android version 7
Security patch Feb 2018.
I contacted Vu Customer care +91-22-45417000, they denied any software support. I have never received an update for this tv. not even security patch. I should have opted for another brand.
they good market in india for budget range . don't knw y they r not interested in india since 2020 .
Recently bought VU 85QPX (85 inches), however not able to download or update any app from Play store. It just shows download pending. Pre installed apps Netflix and Amazon Prime are working fine however Hotstar needs an update. Also not able to install any other app.
Have tried the various cache clearing solutions available on social however no luck.
Any suggestion would be very helpful.
Try using amazon firestick. I had a Vu TV that only played Hotstar on Firestick.
Is this the display issue?
Is it cracked/broken
Vu pixelight tv
The tv is wall mounted and not hit by objects.. Then how could this happen?😭 Any idea ?
I called vu customer care ,1500 for visit.. If it's a display problem, no point in spending 1500.
Waiting for opinion from forum members.
Pls check my previous post. No physical damage but it seems some internal crack
I think this can happen only if the quality of the product is very bad. Any vu users faced this problem?Please reply
