Wall mount Centre channel speaker- Suggestions
mshifi
hyderabad
Hi all, Looking for suitable wall mounted centre channel speaker. Seating distance is about 15-20 ft. Should be light weight. Wattage about 150w max. Appreciate any suggestions. Have been using a B&W centre speaker and looking at an alternate mounting arrangement. Regards
Looks good any link to buy? I am also looking for good center speaker wall mount
I don't think Polk CSi A6 and CSi A4 can be wall mounted on nails. Need to have a shelf of center channel wall bracket for them.
XTZ Spirit 8 and Spirit 6 center channel speakers can be wall mounted on nails. XTZ flush mount bracket also available.
It is recommended to have timbre matching center channel. Which towers/bookshelf speakers are you using as L/R
My mistake.
I have Polk Rti A1s and a CSi A4.
Since my bookshelves are wall mounted, I assumed the centre channel also has wall mounts.
Just had a look. They dont.
