WD 220 or BA A26 for Norge 1000
Thanks for sharing this......from what i read...the board is very sensitive.......it has no high level connections which you find on some subwoofers....you need to read all instructions clearly before using it....
You can experiment (at your risk) using the record out ports with a EP2 RCA able and check on very low volumes of the sub amp....then if all sounding fine....slowly increase the volume based on the kind of speaker connected.......
