WDTV live: audio clipping issues
Santy
Bengaluru
OK I don't really bother whether it can passthrough HD audio or not, atleast for now.
But come on, this is my primary source for music- the dreaded clipping issue seems to be back after some recent firmware upgrade (must be wdtvlive_1.06.15_V).
I have read that there is an unwanted audio gain added at the output (SPDIF). Some say it is fixed, some say it still exists. May be it was fixed but I am very sure it came back after some recent firmware update. I play FLAC and it clips. I play MP3 it clips: No matter what volume I keep in my receiver, it clips (surprisingly, it does not clip while playing 5.1 audio)
I have some plans to expand my stereo setup (adding a DAC) only on the hopes that this tiny player would do justice being a good source. But it is terrifying to know that (i) the clipping issue still exists and (ii) the player down-samples the digital audio to 44khz or less.
Who shares my worries?:mad:
Have you tried reducing the volume for music tracks from "WDTV" Remote? The volume on player only works for PCM tracks.
Yes, they dont have a dedicated volume button on the remote. but they do added a plugin later. Plugin: VolumeControl
With that plugin, you can use up/down button to change the volume. By default, the WDTV volume level is max (100)
Thanks. You mean to say I must flash the player with custom firmware? I have no idea how to do it, will have to learn the steps through. I wonder if we put in a custom firmware, do we lose the recent upgrades/fixes done by the official release?
And anyone else has this clipping issue?
