@Jaudire/All.
If a 40w p/ch amp is good enough to drive floorstanders, why would the companies produce a 80w/ch amp and price it 1.5-2 times? If the obvious difference between them which is the wattage does not translate to better sound, how is the extra money for the higher wattage amp justified?
I have a NAD C320 which is 40w/ch @8ohms and am planning for floor-stander. These amps perform exteremely well with BS. I haven't even crossed 11 O clock position in this all these days. Should I even consider upgrading to C355BEE (80w/ch) now (considering Iam tuned to NAD sound)? Upgradation is my current plan and reading this thread makes me wonder why.
I ask because the sound signature between the above two is same when I auditioned and only wattage varies and a lot of people buy the higher wattage version also. I want to know the rationale.
Also, I am not sure I will be able to tell them apart in a blind test. Never took the test though.
Your inputs will help me decide.
Edit: More info.
While I haven't decided on the speakers yet, MS Aviano 6 and Paradigm Monitor 7/9 are forerunners now. Former is 88db and latter have 94/96 db sensitivity respectively.
Assuming I select one of them, will the C320 hold up? More importantly, what will I miss if I don't upgrade to C355BEE. I never considered the C320 a pair to these FS, thats why these questions crop up.
Edit: More info.
