Wish u all the very best in your persuit of getting Japs the justice that you think they deserve...meanwhile allow me to enjoy my all "european" car hi-fi and home A/V setup that I truely enjoy listening to for as long as they last...until that time I would continue to be biased towards those amazing brands from europe...thanx
hi everyone,(gunbir,jb,ajay a.k.a. b&t)
just joind this forum.
hi avex,
you comparing bremen with japs?? well some of the japs im familiar with (clarion hx-d2, pioneer p80rs etc) can kick the sh** out of americans and europians. try and compare the spec of the best you think from europe with a clarion hx-d2 or for that matter a pio p80, you'll know what im talking.
ok here are the specs for your blau bremen..
Bremen MP76
Radio
FM, MW, LW, SW
Codem concept DigiCeiver
DDA (DigitalDirectionalAntenna)
Optimized digital channel separation (SHARX)
42 presets
Updated station list
FM frequency response (Hz) -3 dB 42
MW interference suppression
Connection possibility for second FM-antenna
CD
CD-R/RW-compatible
Frequency response (Hz) -1 dB
CD Mix/CD-Text
DMS (Disk Management System)
MMC/SD
Card reader for MMC/SD
Formatting FAT 16
MP3/WMA player
Playback of MP3/WMA*
Display of up to 127 directories/file names
Display of ID3 tags up to 30 characters (V 1)
Bit rate 8 – 320 Kbit
Supports variable bit rates
Amplifier
DSA Max (DigitalSoundAdjustment)
Dynamic Noise Covering (DNC)
Self-calibrating equalizer
Number of channels/bands 4/27
Sound-/ Hall effects
Runtime adjustment
Active 2-way frequency devider
High-pass filter separate for front/rear
Source-specific sound settings
Sound presets (music)
X-Bass with variable center frequency
Preamp-Out 4-channel (5 V), gold plated
Internal power amp on/off
Aux-In 2
Sub-Out: var. gain/frequency
Center out (adjustable)
RMS power (DIN 45324) at 14.4 V 4 x 26 watts
4 x 50 Watts Max. Power
Miscellaneous
Display technology Full Graphic DOT
Flip release panel motorized
Softkey operating concept
Display colour VarioColour (4,096 colours)
Keyboard illumination VarioColour (16 colours)
Display brightness
Angle setting
Variable welcome message
Theft protection removable flip panel
Connections: dimmer/telephone mute
Microphone for Automatic Sound Adjustment included
TMC-Out FM
Prepared for telephone/navigation voice output and audio streaming via external Bluetooth interface (optional)
Window antenna included
Preamp-Out cable included
Dimensions (W x H x D) mm 179/52/160
here are the specs of a low grade dhik chik jap.
clarion hx-d2
TUNER SECTION
Frequency bands
FM: (MHz) 0.05MHz steps 89.0 to 108
MW: (kHz) 9 kHz steps 531 to 1629
LW: (kHz) 3 kHz steps
FM usable sensitivity (dBf) 9
FM 50 dB quieting sensitivity (dBf) 15
FM alternate channel selectivity (dBf) 70
FM stereo separation @1 kHz (dB) 35
FM stereo freq. resp. @ 3 dB (Hz) 30 to 15,000
CD SECTION
Wow/Flutter (WRMS) Below measurable lmits
S/N ratio (dB) 112
Frequency response (Hz) 5 to 20,000
Dynamic range (dB) 100
Harmonic distortion (%) 0.003
GENERAL
Dimensions (W H D), mm 178 50 178
Remote control (W H D), mm 52 125 12
Weight (kg) 1.7
Power consumption: less than 1.4 A
Speaker impedance 4Ω(4Ω to 8Ω allowable)
* Dual 24-bit / 96kHz sampling digital to analogue burr-brown converters and DSP
* Built-in 4-way crossovers
* 5-band parametric equaliser
* Digital time alignment for each line level output
* 8-channel/4-volt gold plate oxygen-free RCA output
* 0.5dB-step electronic volume adjustment circuit
* Copper plated chassis
* External DC/DC converter
* CeNET control of: 6-disc CD changer, and TV tuner
* 2 x 2-channel AUX inputs
* Zinc die-cast faceplate
* Fiber optic input/output
* Vacuum florescent display
* 18FM, 6AM station presets
* CeNET iPod interface compatible
96kHz Sampling D/A Converter
this jap is an audiophile(autophile lol) grade head unit and the one from the blau is a run off the mill packed with features great value for money HU.
you need 27 band eq?? most audiophiles dont use an eq. everything is flat. this is how you listen to music(IMHO). you dont need any eq or loudness or anything.
i have a pio 6850. you can call this a piece of crap with dhik chick sound. but sir the dhik chick is there only if you use the eq. i dont. and i get great sq out of this budget hu.
jasdeep can the bremen run in a active setup? like gunbir is using?
does the bremen have the facility to switch off the display?
sir, what i have written is all bull crap. the fact is you dont need a super duper hi-fi hu if you are satisfied with a low grade one. its all about how you prefer your music to sound. no brand is better than the other. same way no european is better than jap and vice versa.
do you have any idea where most of the electronic are manufactured now?
if you like european so much, why do you drive a korean? if im not wrong you drive a getz.
cheers
clip
take it lightly bro
