Dear all; I am in a bit of fix. I have already invested in some wonderful speakers, the Focal JMLab Dome 5.1 speaker system. The specs are:
Nominal impedance 8 Ohms
Minimum impedance 4 Ohms
Recommended amplifier Power 25 - 100W (per channel)
Now, I want to buy the Yamaha RX-V1900 AVR Receiver with following specifications:
Minimum RMS Power at 8 Ohms: 130 W
I intend to use the receiver only in 5.1 configuration.
My concern is, would this receiver damage the speakers? Would the audio quality be impacted at high volumes? Is there a way around? Should I just not consider this receiver?
Thanks all and appreciate whatever inputs you can give me.
