I am trying to build systems that sound significantly different from each other and have distinctly different strengths
Currently my lineup includes (along with what their strong point is)-
Accuphase+Harbeth M30 - Rich, musical - excellent for vocal, jazz, etc
ATC SCM40+Hegel (earlier had active ATCs) - Transparent, dynamic - excellent for almost all well recorded stuff
Genelec 8040+Freya+ pre - All the advantages of an active system, excellent for rock and metal
Harbeth P3+Leben - night time low volume casual listening
I want to replace the P3+ Leben because the Accuphase+Harbeth M30 does pretty much the same thing (and does it better in most ways) with something else markedly different. Options I am evaluating are:
1. Leben+Zu Audio - more dynamic lively sound of high efficiency speakers
2. Leben+ big JBLs - more dynamic lively sound of high efficiency speakers
3. Leben+Tannoy Prestige/Audio Note - a bit more toned down compared to the JBL and Zu options (but will it sound too similar to the Harbeth?)
4. Replace the Leben with a SET amp + one of the above high efficiency speakers
5. B&W 8xx diamond series + McIntosh - typical sparkly hifi sound different from what I have with any of my combos
6. Rethm Saadhna + SET amp
7. Something high end with an ribbon tweeter?
8. Go higher end to Wilson Audio/Avalon/TAD etc (used availability will be a challenge)
Any thoughts on any of these options or other suggestions I have not considered?
The main criteria as I mentioned above is to put together something that presents music in a markedly different way than my existing systems. Budget is flexible within reason.
Thanks in advance
Thanks in advance
