@amrutmhatre90,
@k-pad,
@AKT I got both the cables today.
The armoured cable is a disaster. The armour is actually steel wires running across the length of the cable. It is not a continuous shield. There are gaps between the steel wires. But it is just Rs 244 down the drain. They are so stiff that I will be able to use them as a walking stick when I get old.
The polycab cables are good. It requires effort to remove two sheaths of pvc coating and untangle the braid. It took me around 5 mins to do this.
Also I was able to solder on the braid. The braid is tinned copper.
Here is the picture of the finolex armoured cable. Please don't buy this, unless you want to use this as a weapon of defense or as a walking stick
I had to use a hacksaw to unsheath one end of the armoured cable.
EDIT: Just got an idea. Using two of the steel wires, I can pull those to cut through the outer pvc sheat and completely remove the 3 cores inside. I can just buy a pvc sheath and make a new cable.
