Whether to Upsample? Yes or No?
My findings here across a bunch of dacs that I have access to:
Yggrasil A1 - no point oversampling, red book audio sounds the best on this. Source matters pretty significantly since the USB port on this is not good. AES > coax > the other inputs. Similar results with gungnir a2.
That said the biggest sound difference for yggy and Gumby comes from leaving them on. About a week for the yggy and 48 hours for Gumby.
Holo May - loves high sample rates both over pcm and dsd. Worth using hq player - not source sensitive and the streamer doesn’t really matter too much assuming it’s not a noisy PC.
T+A Dac 200 - need upsampling to dsd. PCM isn’t as good though personal tastes vary
A note on Hqplayer - for dsd upsampling the most important option is the modulator that you select not the bitrate. So upsampling to dsd 512 using a poor modulator can make the sound worse IMO. The high end modulators require serious grunt to run
