I still use NOS tubes in my preamp and not the modern Chinese and Russian made tubes.
Russian Sovtek 6922 tubes are reputed for really good sonic quality. Particularly the Electro-Harmonix manufactured ones.
What preamp do you have btw?
TIA
Dali Lektor 1 - around 20k
Monitor Audio Bronze BR2 - around 20k
Mission M33i - around 18k FLoorstander
Think you can audition these and make up your mind as to what exactly you want.
Heliumflight,
I do not know anything about the sound of the 70's and all that technical stuff but I can list out some speakers in and around the budget you have specified based on which you can audition and find your own choice.
As someone has mentioned wharfedale 9.1 and 9.2 would be within the budget other than that here is the list
Tannoy Mercury F1 Custom - around 15k
Mordaunt Short Avant 902i - around 13k
You may want to read up on the Usher S520 and add it to your
..... I've finally narrowed down on Dynaaudio- 52 bookshelf speakers.
I have a Bryston B- 60 integrated amplifier which is rated at 100 wrms @ 4 ohms; will it be able to drive these speakers without going full on volume control?...
Thanks a lot to you Audio Gurus as I would have burnt my fingers in this process..... I've finally narrowed down on Dynaaudio- 52 bookshelf speakers.
Whose the distributor in Delhi for the Dyna's or any second's available
Once again thanks a ton to you all
