So i have decided to upgrade my audio setup. And i want to eventually build something exciting. But spending so much on a dream system all at once is a problem.
So i though i will buy good equipment in stages.
I listen to a lot of music and watch Movies as well. I have A gaming PC which i want to hook-up to the system. I have a ASUS DirectCU II Radeon R9 270X. Maybe later on i will buy a Blu-ray player / Media player to play all the MKVs.
Eventually i want to build a 5.1 system. But as of right now i think i will build a 2.1 system and add the rest a few months later.
After reading a lot i came to the decision that i want to buy a good AV receivers since that will be at the center of the entire system for quite some time. I decided to go for the Yamaha RX-V479. Its around 40k on ebay and 44k on amazon.
As for the 2 speakers i thought for now i will go for bookshelf speakers. Since i like in Mumbai, i think its sufficient for my room. Later on if i gather up enough money i can convert them into rear speakers and buy tower speakers.
I decided to go for the ELAC Debut B6. Read some really good reviews about them. They cost around $280 in the US. I called the Indian distributor. He said they are available for 35k. I cant find them on any online retail site.
For some time i considered waiting for the ELAC Uni-Fi UB5. But if they cost $500 in the US. By the weird pricing logic they will cost around 60k in India. So right now i have dropped that idea of ELAC Uni-Fi UB5 and decided to got with a pair of B6s.
So now all that left is the Sub-woofer. I dont want to spend more than 50k on it.
Right now there are 3 options that i have thought of
Klipsch R-12W (43k on ebay)
BIC America F12 (36k on Amazon)
BIC PL-200 (43k on amazon)
ELAC - S10 - Debut Series (33k on amazon)
What do you guys thing ? Which one should i get ? Are they any other options i have not thought of ?
