Every cable is equally important to hear the system at its potential. Which ever cable is the present weakest link in your system, the upgrade of that cable will give you the biggest noticeable gainsi reckon IC has the most impact...what's the view of believers?
diplomacy ki bhi koi seema hoti hainEvery cable is equally important to hear the system at its potential. Which ever cable is the present weakest link in your system, the upgrade of that cable will give you the biggest noticeable gains
haha...okay thendiplomacy ki bhi koi seema hoti hain
Excellent @arjThere are 2 dimensions ie 1. where is it placed and 2 what cable is it
for 1. the Higher the cable nearer to the source, the most important then the amplification and then the speaker..of course not all cables are needed for alll but the idea is anything before the amplification makes the most impact
For 2 Digital cable > IC>power cable > Speaker cable as a general rule but except for the digital cable theya re all very component dependent ie what works for one may not work for the other
IC between a cdp and pre is more important than between pre and power, Power cable at source is more important etc etc..as long as your equipment is sensitive to one.
These are all guidelines but the factors of A. what is right and B. What you individually like will make every combination unique especially with powercables.
to all non-believers....try this IC...if your system doesn't take a giant leap in terms of overall clarity and depth, mera non existent mooch uda denaI have ASI Live line power cable and ASI Live line Reference IC which I am not using and if anyone would like to try.
This is where "violent" disputes on power cables come up.. but everyone can have a view but what works for you is what one should go for !..The conclusion I’ve drawn is, if the power cables indeed made a big difference, then the manufacturers of components running into lacs of Rs wouldn’t have minded spending 5000 or even 10000 on including a custom power cable, instead of providing the commoditised black cable.
No, it can't be melted as it's teflon dielectricsThen, did you melt your silver IC
To give some perspective to this post, sharing group delay measurements with silver and copper IC cable for my setup and room,I have tried various kind of wires and configuration for my IC cables and till last week was using a single core pure silver cable for all equipment connection. The sound was hallow with that and did not know the reason. I measured my speakers and I noticed that there was a severe group delay in mid bass till 2khz of around 50msec which was huge. Below 100hz the group delay was even higher than 250msec. I then realized something was wrong somewhere and I suspected the IC cable.
Since I had scrapped all my previous wires to remove clutter, I started fresh with my time tested polycab telephone wire which is a 24awg single core with PE dielectric. As the intention was to check the group delay, I made a 2 + 2 core twisted cable of 1.5 meter length. They had an internal capacitance of 155pF ( measured). I again measured my speakers and the group delay fell from 50msec to 8msec in the midbass and midrange region. To confirm this I restored back to silver cable and again measured and the group delay was again 50msec. Wow, this was a discovery for me - TBH. I then went ahead and replaced all my silver wires with the telephone cables. As the telephone cables were high capacitance ( around 155pF), I needed to work on the cable geometry to reduce that. Yesterday I purchased a 10mm hallow PVC tube ( the one you use for water filter etc), inserted a 2 core wire for the hot, and spiraled another 2 core wire across the length of the tube for the cold wire. Due to the isolation the internal capacitance dropped from 155pF to 44pF for the same length of wire.
In my setup, somehow a high capacitance IC cable just don't work. It makes my setup sound bright, fatigued and distorted in the HF. The change of IC cable wire from silver to copper and using an unique DIY cable geometry had a significant impact in group delay, bandwidth and subjectively the tonality and soundstage. I mostly will be settling with this cable as final because I have already tried Belden 2 core shielded cables on my rig and they too sound very horrible/bad in my setup. I have measured a 250pF cable capacitance for the Belden wire btw.
PS: Any FM using low capacitance IC cable - please share your experience.
Thanks for looking at this longish post.
