attached along with previous messageOhh that's good.. can you share some pictures?
Got my Wiim Pro yesterday. Honestly the internal DAC is quite good. I had no reason to find faults compared to the Audioquest Dragonfly. It was not that some details were missing or the internal DAC is biased or anything of that sort. As Mash mentioned, one can easily live with the device without the need to add a new DAC. The ease and convenience is top notch and so is the app. I loved the equalizer in the Wiim app though i usually leave the equalizer untouched. I also found myself enjoying music rather than being obsessed with SQ/ soundstage or anything else. I used the internal EQ in the app to emphasize a bit of higher frequencies when listening through the Micca speakers. Even a slight change to EQ makes a lot of difference.Can you compare it's sound and performance? We can get some idea. Inbuilt DAC sound also need to know.
I' m sure Wiim will address this given the slew of updates. I was a bit worried yesterday since the device would randomly drop off the phone connection. But i realized it was on account of the iphone switching wifi networks at random (i have 2 service providers). After i fixed that it was all ok. How are you finding the quality of the DAC vis a vis the Audiolab's DAC or the Topping E30 ? I am not so fussed with the bitperfect part so long it sounds niceVery well summed up.
Just to add, if one uses EQ I think it doesn’t do bit perfect.
But I agee on the ease of use, its seemless. One gripe I am facing is when using ethernet the device goes to sleep mode randomly and to wake I have to restart it.
Strangely this doesn’t happen with WiFi, many users are aware about this and currently no fix.
Its been months no fixI' m sure Wiim will address this given the slew of updates.
Both Audiolab and Topping are superior, infact I don’t use the inbuilt since Pro has two outputs.How are you finding the quality of the DAC vis a vis the Audiolab's DAC or the Topping E30 ? I am not so fussed with the bitperfect part so long it sounds nice![]()
Oh man, just when I had convinced myself that I dont need a DAC............I was in fact thinking of Topping E50 or Chord Mojo 2Its been months no fixbut it doesn’t bother me, now I just turn it of when not using.
Try out a dac and WiiM combo, you will enjoy it.
Oh man, just when I had convinced myself that I dont need a DAC............I was in fact thinking of Topping E50 or Chord Mojo 2![]()
hold off for a bit, if possible try out a loner DAC from a friend, you might get some reference.
Sure will try that.hold off for a bit, if possible try out a loner DAC from a friend, you might get some reference.
where did you buy?Finally received it yesterday.. bought it from US... testing ...................
Through friends from outside india.How are you getting it guys. Please provide the link
Have placed on order for this on Amazon US.Through friends from outside india.
My colleague bought it from US.
