Wooden 5.1 HTIB.
Rockfella
Gurgaon/NCR
Hi all,
Need suggestions to buy a HTIB. Obvious choices are ONKYO HTIB 3400/3500 but the end user doesn't like black finish so was wondering if there are options in wooden finish setups?
The HTIB will be connected to this:
ASUS - Multimedia- O!Play Mini
and a 32" LCD.
TIA.
I doubt if they are any HTIB with wooden finish other than black. If you are ready to look at a seperate AVR and 5.1 speaker package then you will have some speakers with wooden finish options, how about this option?
What are the options? The room i wanna keep it the HTIB is comparatively smaller and the Onkyo 3400/3500 will be way overkill, there was/is a Pioneer model for around 18k... can't find it online now...
Thanks bud, i settled for the Onkyo 3500 :)
Look at these combo - Wharfedale Moviestar 65+ Super 5.1 Speaker System or Wharfedale Moviestar 70+ Super 5.1 home theatre speaker system
You can also build a system with any AVR of your choice and some wooden speakers like the Wharfedale packages. If you visit
You can also visit Onkyo and they should be able to offer your something closer to the HTIB you mentioned with their own wooden speakers or some ELAC speakers for the front speakers, but the price might be a little higher.
