At Home Internet was Down from past 15 Days, therefore I was not able to reply to messages, e-mails
slightly off topic - how to get a linear psu for a low powered computer? Can this be used?
what would be the cost of complete amp assembled and tested?
what about kits?
Downloads : [url=http://www.firstwatt.com/downloads.htm]First Watt Manuals[/url]
Toroidals are available on order from Miracle Electronics here in Bangalore-I have bought from them many times and am more than happy.
I am not working with suds' pcbs, but I am building the F5. I got my transformers custom made - they're not toroids, but that doesn't really matter. 18-0-18, 8 amperes continuous, should be enough for an F5. they cost me 750 each - 1500 the pair.
The most expensive things are the heatsinks, I'd like to know what suds/others are using. I got mine locally @2500 each - they weigh around 6kg each and are double-finned.
I tried the online enquiry form for Miracle. I haven't got a response yet. Do they require a minimum order quantity for custom requests?
Do you have a contact number/person in Miracle I could talk to?
Thanks!
Let me know if you don't get through to Miracle, I can give you a Salzer's rep's contact from whom you can order direct...
It's not about the size - it's the thermal rating that's important, which is determined by heatsink design. The fins and the base thickness are important - 6mm base minimum,
2.5" is too small, FWIW. Nelson runs the reference unit in a 3U case with 300mm heatsinks (IOW, 12" x 5" x 4" per side). You'd be surprised at how thermal ratings degrade with the amount of heat input and rise above ambient shoots up out of control. The F5 dissipates roughly 60 watts at idle, so a 0.4 C/W heatsink will be around 60 degrees, which is very, very hot, enough to burn you.
I tried monkeying around with locally available heatsinks for a while, but the only thing that actually helped was looking at the catalogues for Fischer and Hammond, and approximating the size and weight of the required sinks. They turned out to be much, much bigger than I thought they would be.
Would look forward to your pics and results. Am stuck with another project ATM and can only focus on the F5 week after next.
