Xtreamer Media Player (XMP) Owners Thread
thanks Dushie..... btw where can I buy Xtreamer in B'lore and what price is it selling in b'lore. ? Can you please give me any dealer contact detials....
2. Does it support DVDs with menu option ?
It supports DVD RIPs with full menu. :)
I have been ripping my DVDs with Nero. Just make an image (.nrg) of your DVD.
.NRG is not displayed in the Xtreamer media library.
So, just rename .nrg to .iso and this way it is visible in Xtreamer media library and then u can play it as a full fledged DVD. :)
This is if you don't have problem with original size of the DVD and you don't want to take out few extras.
Guys, please share how do you do it specially if you have any better and simple method to do it.
Can xtreamer play copy protected/ commercial movie DVDs from an external DVD rom connected via usb?
Can it also play blu rays from an external blu ray disk connected via usb. Please respond asap.
Question for the Xtreamer owners.
How does it work as a streaming only device over 802.11g ? If you have a laptop/desktop at your home already, how good is it at pulling media from those PCs ? Or do you need to upgrade to a 802.11n ?
Does the process become better if you are using something like Tversity TVersity - Home?
802.11g works fine, i have been streaming files through wireless on the same and never faced any issues.
If you dont mind explaining to a noob, whats the process of sharing files/folders from any PC ?
You just do windows share and Xtreamer finds the folder ?
That's right, i have shared my movies folder in my pc, through the xtreamer i log in to my pc putting username and password and save it as a short cut . then u can access the folder and play files from it.
Well if it is that much important to you i think you can try this -
You can share a DVD drive on the network and use AnyDVD on that PC and play that DVD. Here AnyDVD running on the PC strips the content protection on the fly for you.
So the above should work if you really want to play a content protection disk.
I don't have a BR drive to test, if someone can test out the same and report out it will be great
Personally why go through so much trouble, what i did was asked my friend to copy the disk files on a hdd and you can play from there and it worked fine.
I ordered through xtreamer.india and received my eTrayz during the week. I will start configuring it tomorrow:yahoo:.
Something I noticed is that the new antenna that I got with it has a larger packing and also says Wireless 300 Mbps(which if I am right is the 802.11 N that support 300 Meg wirelessly). Whereas from memory, the one that I got with my xtreamer when the product was launched was 150 Mbps(N draft). Can Sumit or someone confirm the news antennas are different from the earlier batch please?
Also, while comparing them side to side, my son distracted me and I mixed up both. Now I don't know which is which:lol:. From a distance, they look almost the same but have small differences in shape. Just curious:)
I just had a word with Mr. Sumit Kumar of Xtreamer India and he did confirm me about this new antenna which supports maximum speed of 300 Mbps whereas the older one could support maximum speed of 75mbps as it runs on 2.4 GHZ wireless technology which maxes out at 150Mbps whereas the 5 GHZ wireless technology sopports speeds upto 300 Mbps, so I assume that the new lot of Xtreamer antennas are 5 GHz band compatable which would eventually help to a lot on extent for a setup like mine where I have a dual band router and streams movies wirelessly from Etrayz to my Xtreamer.
Could anybody confirm my above assumtions?
We just confirmed that the packaging is new and "Wireless 300 Mbps" is printed on the box.
We have not tested this antenna so can not comment any further. However, HFV members can read the specifications from the image attached. :)
Better resolution images can be downloaded from:
http://rapidshare.com/files/346642102/11n.zip.html
After looking at the specifications on the box its confirmed that this is just the new box packing but the antenna remains the same as the specifications are identical to the old antenna, also it doesn't support the 5 GHz Wireless frequency so the maximum thoughtput even if its mentioned 300 MBPS on the box is 150Mbps.
Xtreamer Firmware 2.2 Released :)
Release Notes
New features
1. Blu-ray simple navigation.
a. Chapter navigation.(GOTO or Next button)
b. Audio navigation(AUDIO button)
c. Subtitle navigation(SUBTITLE button)
2. Ken Burns slideshow effect
a. During Photo playback.
b. Setup->Playback-Ken burns Slideshow Effect.
3. Hue & Saturation
a. Setup->A/V->Hue, Saturation.
4. Multi Audio output.(HDMI only)
a. Output AAC/FLAC/OGG/WAV 5.1 PCM
b. Setup->A/V->Digital output.
5. Wireless network
a. Static IP
b. WPS
6. DVD/Blu-ray folder auto play.
a. If folder is DVD/Blu-ray folder structure, Appear select window of Browser folder and auto playback
7. New RSS video (HD) sites added in Internet menu.
8. Change custom GUI image.
a. Web page->Setup->TV skin.
b. Support 16bits BMP(656 format)
9. Custom RSS(Personal) option in Internet menu to use users customized script from internal HDD.
Improvements
10. Return button acts as stop button, during video playback
11. Wireless Network performance.
12. eTrayz mount option from UDP to TCP
a. Media Library -> eTray.
13. Internet sites support H.264(mp4) streaming.
14. Internet video playback.
a. Default playback resolution from 320x240 to full screen
b. Fast forward 1.0x->0.5x->0.8x->1.2x->1.5x->2.0x
15. Photo display quality.
16. Recognize ext3 file system in internet HDD.
17. USB HDD detection much faster.
18. Web GUI downloading works stable.
19. Xtreamer Restart from Web GUI
a. Setup->NAS Mode->Restart
20. added fast forward speed 1.1x during Video playback.
21. Change volume window position from bottom to top.
Bugs fixed
22. Official DVD cant playback used by GL811 chip DVD device.
23. MKV+DTS out of sync.
24. External USB HDD detect error.
a. Samsung S1 mini (1.8inch external USB storage)
25. If TS file has internal subtitle, cant display subtitle.
26. Subtitle visible when screen saver is on.
