Rockfella
Hey can you link me up with that thread plz. Thx.Congrats ! It is good that you auditioned other models.
There is a dedicated Yamaha HTIB thread which will help you to get the initial settings.
Its good that u have set aside limited budget.@Kirankj1724 Whats your long term opinion on yht1840? Do you miss Bluetooth or DTS HD master codec? I am also going through the same dilemma of chosing avr+speaker (slow upgrade) or HTIB and have set aside limited budget.
Hello,Glad to see this video here.. it's made by me.
I have upgraded my system since the purchase. Added Klipsch R14 as front speakers & Dali Zensor Pico Vokal centre channel speaker. Also I have been using my car's subwoofer Rockford fosgate 12" with the system. Yamaha sub is doing it's service in my car.
If he has the yht 1840, Rockford fosgate sub can be directly connected to the passive subwoofer port, thats what I did when I had the product and it worked fine.Hello,
My friend has Rockford fosgate 12" & 4D furnisher 300 watt subwoofer amp. He wants to use this setup in home Theater. What's the steps or procedure to do it? Plz guide.
Thanks for the response. Sorry, i didn't mention the AVR. He has bought Denon AVR x250BT. On backside, its written as Speaker impedance 6 - 16 ohms. While, rockford is 4 ohm subwoofer.If he has the yht 1840, Rockford fosgate sub can be directly connected to the passive subwoofer port, thats what I did when I had the product and it worked fine.
This Denon doesn't support passive subwooferThanks for the response. Sorry, i didn't mention the AVR. He has bought Denon AVR x250BT. On backside, its written as Speaker impedance 6 - 16 ohms. While, rockford is 4 ohm subwoofer.
Ok. So, if he connects the 4D subwoofer amp to the AVR and Rockford speaker to the 4D AMP. Will it work?This Denon doesn't support passive subwoofer
I saw some videos on youtube regarding this you can search and watch them for better understanding.Ok. So, if he connects the 4D subwoofer amp to the AVR and Rockford speaker to the 4D AMP. Will it work?
I have no idea about thatOk. So, if he connects the 4D subwoofer amp to the AVR and Rockford speaker to the 4D AMP. Will it work?
Thank you.I have no idea about that
Ok. ThanksI saw some videos on youtube regarding this you can search and watch them for better understanding.
Car sub woofer can be connected to Avr with car amplifier but no idea about the actual performance.
You need ac to dc converter also to run car amplifier at home.Ok. Thanks
Thanks for your response. Will go through some you tube videos also to know the process in detail.You need ac to dc converter also to run car amplifier at home.
Bro I'm also new to HTs.Hi @SiddharthY
Over the past 2 years of ownership, On the audio side, I have made only one major change to my setup (fixed the weak link). I've purchased a used active subwoofer (Taga Harmony SW10 V2). The deal was irresistible, got the unit in excellent condition for 16k
With the above change and some re-positioning of my setup, I'm a proud and a very happy user of what I've put my money into.
Talking about Bluetooth, I never really felt the need because my source is still the HDMI port of my trusty old laptop. I've also purchased a fire stick that's plugged directly into the receiver and satisfies my streaming needs for now.
The best route based on my experience is to get a AVR + Speaker package first and add in a sub at later point of time as per your budget. I would suggest you to pick the HTiB route only if you are on a tight budget.
You can PM if you have any further specific queries as well. I'll be happy to help.
Edit : Happy to know that users are still reading this 2 year old thread
And I must say, it's the most complicated thing ever and I almost got a headache from it.
I was initially looking at used avrs and speakers (since my audiophile friends asked me to do that) but was shocked at the prices.
A good Avr plus Speaker and Sub combo (used) will cost me upwards of 35k in 2022.
So is it a good idea to get a new yht1840 at 31k?
Also, I looked at other options and frankly, anything other than this is upwards of 50k and out of stock. So seems like this is the only option I have for now at this price.
Budget is not a big issue but it is something we are new into and I'm not willing to spend almost double the money for something that is maybe 10% better.
I'm also looking at the Onkyo HTS3910 but it is out of stock all the time.
Any other systems at this price you guys would recommend?
Hope you guys see this and awaiting your reply.
