magesh_magi1
Vinay , Thanks for the detailed review. I've purchased YHT-196 reviews here in Hifi. Couple of doubts I've regarding the set up you've mentioned
1) //It has 17 DSP settings for movies music and gaming. Set it to straight enhancer setting// Straight Enhancer is good for movies also? It is mentioned in manual straight enhancer is used in compressed audio sources only.
2) Since there is no USB in this Amp I play movie in my laptop connected through HDMI. In Laptop I'm using VLC with ( Directx audio and Dolby sound on ) , I feel that the dialogue volume is low. What might be the case.
3) I'm complete noob in HT, this is my first purchase og any Audio product. What settings in AMP will enhance the movie watching ( I very rarely listen to music) from my laptop using above set up. ( Should I let the computer or Amp process the sound? is there any setting in Amp allowing the Audio from Laptop as it is ?)
4) Do you think any specific Bass and Treble numbers are good for movies or Sound filed programs given in Amp is enough to achieve a desired experience.
As far as settings I've set the speaker distances correctly as mentioned in your review.
and the basic connections using manual.
