sap2nirvana
Update on 28-Aug-2013
Made some great progress. Following work is completed
1. Finished all the absorber panels
2. Work in progress for bass trap panels
3. Work in progress for wall panels
4. Wiring for lightings completed. Lights will be installed on Friday / Saturday
5. Screen panel mounted on the wall. Screen cloth will be fixed on Friday
6. False ceiling framing done. Now just need to put the tiles on the frame. Expected to complete by Friday.
Here are some pictures
Building Absorber panel using 2'x4'x4" plywood frame and filling it with 4" of Synth PF and 20mm Strand SS. Finally cover the frame using acoustically transparent cotton fabric.
Finished 4" wall absorbers
Finished 6" bass traps. More to build.
Entire Album
ImageShack Album - 13 images
Thanks,
John.
This is awesome man.. hats off to you. now can you share how much did the materials and the labor cost you??
