Interesting. Wasn't aware of such a product. Effective?
We'll find out after you implement it in your build.Effective?
It'll be difficult to know if it's effective in a speaker enclosure unless you're suggesting just this with no stuffing.We'll find out after you implement it in your build.![]()
Can the wall be painted with this
Not only aesthetic. With bigger structures like the plastic plate that holds the binding posts larger holes need to be cut in the cabinet to attach them. This may cause potential air leaks depending upon how it all fits together. Also there is a potential for unwanted resonances. This being a sealed subwoofer, we want to avoid that as much as possible.Is this from an aesthetic point of view?
Sure. In that case, it is ok.I have all material at hand and executing this build myself, hence no labour costs.
At first sight, your crown amp looks fine for the purpose. Let's see how good it is first.My Crown XLS can be used for testing purposes, but I'll have to procure an additional amp for Sub duties.
Sure. We can experiment and see what is best.This will depend on what REW shows me.
This is nice.. So that part is taken care ofSabaj A30a. It has a subwoofer out, as well as a crossover.
Sure. usually when the subs are used crossed over around 100Hz or so, with closer placement to speakers and the room cooperating, one may not need delay adjustments but it needs to be experimented and seen what is the best strategy in this scenario. Since you have a dsp processor for experimentation, it is fine.I have a miniDSP Flex, again, this can be used for testing purposes only. I have to return it to my main system. Depending on the location, if a delay is necessary then I'll have to think about managing the same.
This is almost all you will need to measure and fine tune this subwoofer..Yes. Flex with UMIK 1.
Thank you.Thanks, I value your effort, guidance, and generosity, much appreciated.
Cabinet internal volume-wise, it looks fine. You will have similar response as we had modeled earlier. About 113L external volume. Keeping apart 5L for driver, 6L for bracing, we get to around 100L of internal volume. This looks fine bass alignment-wise and box resonance mode-wise (still the first mode will be around 250-300Hz area as before).@Vineethkumar01 These are the final dimensions. I reduced the height, in case I need to pass the sub under the TV. I have compensated for the height and width reduction by going deeper. This reduction also means that there is now a minimum surface area around the speaker on the baffle, and hence a double baffle is not required. 18mm bracing will also support the baffle.
It's possible that this might be slightly larger than 105L, let me know what you think.
Understood. I'll take a call before I commence bracing.So if you are absolutely convinced that only an 18mm thick baffle is needed you can go ahead with it. But otherwise, I would be more comfortable with a double baffle.
I have rerun the seams and they're well sealed. I want to make the box as airtight and inert as possible.1) Minimise leakages in the box: Carefully inspect and ensure that all joints are proper and use glue/appropriate other material to seal the gaps if any.
Alternative.
Metal paste? It'll be quite a task to apply it on the whole of the insides, especially with the bracing on.Alternative.
Metal Paste. about 100-200 per kg(with hardener).
where short shelf life once mixed ( 10-15 minutes)
Agree.Metal paste? It'll be quite a task to apply it on the whole of the insides, especially with the bracing on.
TuffKote is to be applied like paint. Either by brush or spray.
Hi,The thing that goes BOOM is here.
Coffee cup for comparison. One of them makes you go boom from the rear.
Looks like the Q Acoustics logo?
Congrats.
Is this SB Acoustics driver? From where did you purchase this and for how much?
Thanks, Vineeth!Looks really nice..![]()
It's the cross-section of the plywood. I cut about 20 pieces of 10mm width, and then stuck them together on the baffle. The baffle is now 46mm. But, the extra thickness is on the outside, so it's fine.What is the material used for baffle.
I plan to plonk it on a 10mm gym tile. Let's see how it goes. Or I can make 20mm high feet out of it.Also what are we planning so as to not let the subwoofer move around during use..
