What purpose are u looking forHi Guys, in budget Class D amplification, which one is sorta proven.. Budget let's say 50k
If there are any similar threads, please guide me to same. Thanks!
Purpose is ease of carrying it around with a bookshelf speaker. One breifcase, solution. and to that effect to do it in a way where power and quality is not heavily compromised.What purpose are u looking for
Hi, could you please guide on which name brand amps using the purifi or hypex ncore modules are easily available in India. I see a lot of good stuff about these but most builds seem to be only available in US/EU. I'm aware of some recent NAD models and heard the M33 recently which was amazing but sits in the organ transplant price category.With your budget, you can go for Purifi (1ET400A) or Hypex Ncore (NC252) based amps.
But, to begin with, you can get the Aiyima A07 (and swap the opamps to OPA 1612) and get an idea of how affordable well implemented Class D has become.
GL
SMSL DA9 is a good bet. Some points that can be considered:Hi Guys, in budget Class D amplification, which one is sorta proven.. Budget let's say 50k
With such a budget , NAD D3020 is not out of reach . Excellent stereo amp! All those SMSL/Toppings and chinese amps are nothing when compared to NAD.Hi Guys, in budget Class D amplification, which one is sorta proven.. Budget let's say 50k
Allo makes similar ones as well in bangloreTPA3116D2 mono block 100w for low budget suplay with cheaper switching 24v 5A perchanel “nice flat and low noise” detail reviewby JohnAudioTech
But the person is not interested in promoting AlloAllo makes similar ones as well in banglore
Really ? I thought it was doing well. Their stuff is sold on diyaudiocart.But the person is not interested in promoting Allo![]()
Would you have an idea about the difference between opa1612 and the lm4562? (Diff in charecterestic sound). They both have different mounting pins too, so how does one go about altering it to fit the A07 ?With your budget, you can go for Purifi (1ET400A) or Hypex Ncore (NC252) based amps.
GL
Lm4562 is a fine opamp. Stick with it is my opinion if you buy that amp.Would you have an idea about the difference between opa1612 and the lm4562? (Diff in charecterestic sound). They both have different mounting pins too, so how does one go about altering it to fit the A07 ?
I'm an off the shelf guyWould you have an idea about the difference between opa1612 and the lm4562? (Diff in charecterestic sound). They both have different mounting pins too, so how does one go about altering it to fit the A07 ?
Quite well. The Allo Digione is Sold out more often than not.Really ? I thought it was doing well. Their stuff is sold on diyaudiocart.
Yes. I am told so. They have the Digione Signature thats supposed to be great as well.Quite well. The Allo Digione is Sold out more often than not.
Thanks n yes i do have the A07 with the stock op amps. Already on the hunt for LM4562 but I'm not finding it anywhere online except Mouser.in & their shipping that costs thrice the amps themselvesLm4562 is a fine opamp. Stick with it is my opinion if you buy that amp.
You're smart....that's what I figureI'm an off the shelf guy
