This is a DAC. It converts wireless digital stream to analog output, if I am not wrong. You would need one more device to take that analog audio, digitise it and stream to the speakers.Arjun, I am exploring downsizing from the hifi to an all in one. And I want to play my CDs too. There are other AIOs with optical and coaxial in, but ‘form factor - price - SQ’ wise the RS150 fits best.
I found this through an internet search - not sure if it’s available here. Also, it is over designed (has a DAC as well as USB-SPDIF converter) for my need. Still hoping there’s something out there for this peculiar need and someone here knows!
Hope this is a trustworthy Indian reseller. Shall speak to them tomorrow:
Audioengine D2 Premium 24-Bit Wireless DAC
Advantages of wireless - The D2 wireless system transmits bit-perfect PCM-stereo simultaneously to up to 3 receivers. This PCM stream is routed from/to the various components of the system (optical transmitter/receiver, USB controller and DAC) via the I2S Bus, which maintains data integrity throughoproaudiohome.com
@sachinchavan 15865 Eureka,
You can do it with this device. It has SPDIF and optical in and it can transmit to to RS150 using bluetooth. And it supports aptX Low Latency (which RS150 also supports) and that is more that CD quaility samping rate.
Oops. Thanks for letting me know. I indeed forgot to paste the link. There are pleny of these available. What you pasted should work. I actually missed out pasting this
Thanks @mbhangui and @bornfi. This solution might work. I shall look up the specific products.Oops. Thanks for letting me know. I indeed forgot to paste the link. There are pleny of these available. What you pasted should work. I actually missed out pasting this
@arj, I agree on the simplification/elegance part. And your comparison of the two companies is spot on. However, my comparison of the McIntosh (RS150 and RS250) and Naim (MuSo 2 and MuSo Qb) products in this category (based on reviews, YT videos and speaking to couple of owners) is contrarian to it. The Naim products sound over-processed (hi-fi’sh) to me. It feels like a filtered/distilled sound. On the other hand the McIntosh alternatives sound more natural and open. The first generation MuSos had a better sound signature in comparison. I’ve compared most of the other available options from other companies too. And RS150 seems to fit my bill best in terms of SQ, price and form factor combined. I was also keen on the Ruark 5 (with class A/B amplification - rare in AIOs), but I couldn’t find any Indian distributor/dealer for the same. Please let me know if there’s any.Sachin, have you considered the Naim Musi Qb ?
may be slightly more expensive range but has an optical in as well as USB and analogue in. For music quality I would rate Naim far higher than Mcintosh which is only a brand name from what it was known for in the past ( mainly Amps) and usually outsources to OEMs for design and manufacture of others . eg their TT was made by Project.. Naim is known for everything from source to speakers and has been on digital for a very long time.
This is far more elegant than adding more and more boxes when your whole intent is to simplify to 1 or 2 boxes.
AptX Lossless is designed to spot 16/44.1 and only output it as bit perfect. It will only do anything higher when the input is higher.Thanks @mbhangui and @bornfi. This solution might work. I shall look up the specific products.
I have a technical question about it though. I know that aptx (as well as aptx LL) supports CD quality based.
However, what about the compression? Isn’t this lossy therefore? Would it give bit-perfect result?
- Compression ratio: 4:1
- Audio format: 16-bit, 44.1kHz
- Data rates: 352 kbps
Are you sure? Because the linked article says “AptX LL is limited to lossy, 16-bit audio, so it won’t be anyone’s first choice for critical music listening”. And “SBC, AAC, and aptX are the most-supported Bluetooth codecs around, but all three are typically limited to lossy compression at 16-bit/44.1kHz, with bit rates that rarely go above 352 kbps.”AptX Lossless is designed to spot 16/44.1 and only output it as bit perfect. It will only do anything higher when the input is higher.
What is aptX? Cutting through the clutter of Qualcomm’s Bluetooth codecs
The world of Bluetooth codecs can be a swamp of confusing technical jargon, especially when it comes to Qualcomm's aptX family. Here's what you need to know.www.digitaltrends.com
You have aptxLL and aptxHD.Are you sure? Because the linked article says “AptX LL is limited to lossy, 16-bit audio, so it won’t be anyone’s first choice for critical music listening”. And “SBC, AAC, and aptX are the most-supported Bluetooth codecs around, but all three are typically limited to lossy compression at 16-bit/44.1kHz, with bit rates that rarely go above 352 kbps.”
How can any codec compress CD quality to 352 kbps without loss? If that were true, streaming lossless at 360 kbps should have been possible. It’s possible that the aptx codec is smarter than mp3 and others, and results in loss that is not easily perceivable. Am I wrong?
Also, since you replied before I added the following question to my previous reply, posting it again here:
“why doesn’t the Mumbai-Pune highway & vehicle analogy apply to BT just like it applies to Wifi? Is BT both a highway and a vehicle?”
I think BT is the highway and aptx is the vehicle and bluetooth will have to compress but considering all the processing in a wireless speaker that may be the least of your concerns.“why doesn’t the Mumbai-Pune highway & vehicle analogy apply to BT just like it applies to Wifi? Is BT both a highway and a vehicle?”
There are many ways to compress data.How can any codec compress CD quality to 352 kbps without loss? If that were true, streaming lossless at 360 kbps should have been possible. It’s possible that the aptx codec is smarter than mp3 and others, and results in loss that is not easily perceivable. Am I wrong?
1. TCP/IP is like a super connected national highway throughout the country. It offers you multiple features. Let say you are traveling from Mumbai to Rajasthan. One particular road gets jammed, you can take an alternate route to reach Jaipur. You can even reach Jaipur via Hyderabad as an example. This highway has multiple things like food joints, petrol pumps, tourist attactions. You have restaurants on this highway where you can bring your own food and eat it there too.Also, since you replied before I added the following question to my previous reply, posting it again here:
I know. But when you rip CD into FLAC, you get bitrate around 700-800 kbps on an average. I wonder if one could compress down to 356 kbps without loss!Compression doesn't necessary mean lossy. e.g. Flac is lossless compression. I will reply to BT in a different post.
Now let me muddy few things for you. You think by using something over wireless will be very good. Remember that the wireless is a very narrow road compared to a 8 lane highway on a wired ethernet. There will be traffic congestion on the road. Sometimes your vehicle need to stop because on this narrow road there are many other vehicles and you have only one lane. All this factors will increase your journey time. In the audio world, this will increase latency. If you are worrying about things like bluetooth, then there are other things to worry about when using something like wireless. And like what @arj is suggesting, using multiple device to transmit device is not a good thing, but if you want to use it, you shouldn't be worrying about such things
I have never done any research on this hence my view is theoretical and not researched and hence limited, and maybe just a perception so you have a better chance of being right . I am sure you would have considered long term support and tech performance regarding driver stability as well . its the conservative in me but anything which is App driven, better be sure will continue to suppport thje app as your Phone OS/Pad os also upgrades. eg I still need to rteain my Old ipod so i can use an app which measures turntable speedas they discontinued it
Second that!Hats off to your ability to put this in such a simple language.
Yes. Good grasp is essential to simplify. But also admire his ability to imagine and articulate those metaphors - an indication of strong intuitive and verbal abilities too.Reminds me of the point that only one with very strong grasp of the topic can put something complex into simple words
I own and actively use both. Got the Naim almost a year ago and found it is a good sounding and reliable performer. Well supported by Naim with updates as needed. The McIntosh is the better sounding speaker and to my tastes better looking. I also like the bass control and visuals - the meter, case finish. It unfortunately is unstable as a network speaker. Airplay is hit and miss and a real source of aggravation. Constant drop outs. Bluetooth is rock solid but I sure as heck did not buy it to be a Bluetooth speaker but that is the Macintosh RS150 comfort zone. Zero updates since it came out. Zero hope at this point of proper performance beyond bluetooth. If you are on a windows system maybe the Macintosh will work. I am in the Apple world with all very new gear, Studio Mac, M1 Pro Mac Pro etc. Good router, stable internet service, highish end ethernet cables... Have tried every combo or permutation of both being hard wired, wi-fi, streamed sources or a Naim Unity Core Server. Listen to jazz, blues, oldish rock and the like. Naim for sanity, Macintosh for sound. Powered speakers if you have the space... I don't so....
Yes, I had read that post. And it was the only one pointing to that issue in all of my search. I also checked with a FM who has the Mc speaker and he isn’t facing the dropouts. I’d be shocked if a premier American company’s product faces problem being used within the Apple ecosystem as most of their sales would be to Americans who mostly use Apple products.I am sure you would have seen this reddit post ..was doing a search since you got me curiousam sure there are opposite inputs as well but its performance on wifi and updates is something I would be worried about.
Then it’d be a short-lived love affair - there’d still be some highs to cherish.the worry I usually have with such all in ones is how will it be 2-3 years from now eg if the wireless radio fails all you can do is throw it away.
I considered it hard and long. Especially for its Analog signal processing as well as VFM. Two things worked against - the form factor (impossible to fit below or besides the TV on the cabinet) and the tube gives it a slightly mushy sound (one that I’ve outgrown from the days I used hybrid amplification).BTW check this one ou
