Help in buying a silent split Ac
I am based in Bangalore. My priority is NOT cooling but a bearable temperature in my room (27 C works well for me). A quiet AC is my top priority. A local AC dealer suggested that since Bangalore does not have extreme weather conditions, and I my AC usage are a few hours at best, even a 2 star rating is good enough. The following models were suggested:
1.0TR Mitsubishi 3 star - MSY-JS13VF
1.0TR Mitsubishi 4 star - MSY-GN13VF
1.0TR Mitsuishi 2 star - MSY-JP13VF
The only reason I would want to go for the 4 star rating is that it’s 19db at Silent mode. The other 2 models are @22db. I am wondering if there is any noticeable difference between the two db levels. The price difference between 2 and 4 stars is around Rs 7k.
If 22db is really quiet enough, I am planning to just pick up the 2 star one. The dealer is offering 30% discount on the MRP. What would you recommend?
And, does one really need an inverter AC given that repairs are very expensive? They have their advantages, no doubt. The lowest db level Mitsubishi non inverter ACs I have come across on their website (Electric) is 26db.
Why don't you consider daikin? They are known for silent operation & should be cheaper too..
go with mitsubishi, have used them and their inverter type is world class, daikin also very good. Make sure the model you buy is fully copper coils internal and external.
Sorry for hijacking the thread....I dont have an AC in my room, which is also my bedroom cum music room. Both the AC's in the other 2 bedrooms sometimes drop condensation below. And since my tubed gear lies exactly below my AC point in the room, Ive been too scared to mount an AC here so far, as a single drop or splutter on high temperature tube will kill the amp completely. So was just curious if anyone else has noticed this condensation dripping from the indoor AC casing. Both the AC's in the other rooms are LG
LG , Panasonic , MHI , OG mostly have the same issue . Problem is with the fins which are too close and the fins have additional punching for more efficiency which causes the dust to get trapped . Regular water washing and not regular "service" will work .
The reason why the lowest DB for non inverter is 26 is due to the fact that the compressor runs at full speed . So the indoor fan cannot spin at too low speed else the coil will freeze . Especially with R32 /R410 gas . With an inverter if low fan speed is chosen and the ambient temperature is not too high the compressor will work at 50 % or lesser . So lower noise .
Finally, picked up the 1.0TR Mitsuishi 2 star - MSY-JP13VF.
Very quiet. Doesn’t make it presence felt. Good enough for Bangalore weather.
Looking to buy 1T & 1.5T INVERTER A/c’s, I’ve shortlisted a 3star MHI SRK13 YXPw6 for the 1T & MElectric MSY JS18VF for the 1.5T also a 3star.
Room sizes are 220sqft & 110sqft.
Need some advise, if I should pull the trigger.
My intent to install the AC in the listening room was only for minimal cooling with least AC noise.
Mitsubishi was the only brand (as far as my research went) that offered the lowest decibel level in the vicinity of 20 db in eco mode.
I stay in Bangalore, where weather is cold for most part of the year; quick, intense cooling was not a priority/nor needed. So, I settled for a 2 star rating. 1 ton AC was enough for my room.
If you want an AC with the lowest noise, Mitsubishi has some great numbers; otherwise there are other less expensive options you can consider.
Just purchased the 1T MHI 3star SRK13 YYM (latest model).
