How Many Watts? - a Guide
aeroash
Mangalore
This is a guide to the basics of power requirements. Remember that this is a simplistic guide, and is intended for beginners to get started. Technicalities can be debated, discussed and dissected, but that isn't the intention of this guide, nor is the place.
Damage to Speakers:
To enable a speaker to produce sound, it requires power measured in watts. The amount of power needed by the speaker is influenced by its impedance. In general, speakers with lower impedance require more watts for a given voltage. In essence, for the amplifier to effectively drive the speaker and make it produce sound, it must supply enough watts to meet the power requirements.
If the power demanded by the speaker exceeds the maximum power output of the amplifier, several issues can arise. The amplifier may clip, which means it fails to accurately reproduce the input signal and instead produces distorted, harsh overtones.
The excessive power delivered during clipping can cause the speaker components to experience mechanical stress and heat buildup, which can lead to driver failure or reduced lifespan, especially in a tweeter. Clipping, in most cases, cannot be heard, hence there won't be a warning before your speakers are already damaged and go silent!
Damage to Amplifier
Impedance plays a crucial role in the interaction between an amplifier and a speaker. While amplifiers are typically designed to handle specific impedance ranges (such as 4 or 8 Ohms), connecting a speaker with a significantly lower impedance, such as 1 or 2 Ohms, can lead to problems.
It's crucial to match the impedance specifications of the speaker and amplifier to ensure proper compatibility and prevent potential damage.
On the other hand, if the amplifier has sufficient power to meet the demands of the speaker, it operates within its intended range, ensuring clean and undistorted sound reproduction.
Typical Scenario:
Question: I do not play loud, I do not need so much power.
Answer: Do not underestimate what "loud enough" is. You might be in a scenario where you want to crank up the volume, unknowingly.
When a 50W amplifier is connected to a 200W-rated and inefficient speaker, the power demand can quickly exceed the capabilities of the amplifier when playing at loud volumes (especially because of peaks in high dynamic content). As a result, the amplifier may clip. And you've quickly learnt what clipping can do from what you've read above!
Summary:
In summary, Underpowered amps aren't the best choice! Have enough headroom!
  1. A higher power amp at the same decibel level will keep the voice coil cooler for longer.
  2. With an underpowered amp, you do not know if you're harming your speakers when you're driving the volume up, until it's too late.
  3. With a larger amp as you turn the volume up the speaker will distort (beyond the speakers' ability) and you can then turn the volume down before permanent damage sets in. This is a better indicator to know the power limits.
Conclusion:
  1. Check the rated power of the speaker.
  2. Use a decibel phone app to determine the ballpark continuous decibel requirement at the listening position.
  3. Use the power calculator to determine your power requirements.
  4. Determine the headroom required for peak signals. Don't go below 15db. While 20 to 25 is ideal for highly dynamic music.
  5. Buy an amp with slightly more power than the peak power requirement.
Suggestion:
  1. For fun, see how big a difference high-sensitivity speakers make in power drawing!
  2. Always buy higher-sensitivity speakers; then again, don't trust the sensitivity ratings published by any brands, especially Klipsch!
  3. Always read independent test results (for example, Erin's Audio Corner) to know the correct speaker parameters, because most brands lie!
Read this article from Crown, thoroughly and then use the calculator to derive your power requirements.
https://www.crownaudio.com/how-much...arly, the peaks require far,enter 10 to 15 dB
Power Calculator.
https://support.biamp.com/Design_Tools/Amplifier_Power_Calculator
Thank you for the post @aeroash.
I have read in this forum that Harman Kardon amplifiers are high current amplifiers with a lot of power.
Since power is directly proportional to the current, I don't get what is so special about the term "high current"?
Isn't high current same as high power?
Or have I really simplified the P=IV formula? 😛
High Current = A faster way to make audiophiles part with their money.
Do see:
TL:DR:
*Harman Kardon used to spend the maximum money on making speakers sound good with high current capability baked into their system. *
Posted in full:
A Technical Guide to High Current CapabilityAmplification.
In 1977 we completed a long-term investigation of existing solid state amplifier design, and concluded that some new directions were needed. Early solid state designers, for the most part, had become fascinated with the ease with which large values of overall feedback could be applied to solid state circuits. They concentrated on reducing harmonic distortion to the exclusion of all else. Designs based on such excessive and obsessive use of feedback tended to measure well on standard distortion tests but they generally exhibited a harsh, irritating sound quality that detractors dubbed the transistor sound, even though it had nothing to do with the use of transistors themselves.At Harman Kardon we had been using sophisticated arrangements of local feedback loops with overall loops in our last tube amplifiers of the middle sixties, and we applied the technology to solid state. We reduced overall feedback to below 25dB – as compared to 60dB and more in competing products – and noted substantial improvements in sound quality. Our design techniques were almost immediately copied by esoteric manufacturers, and low feedback became the audiophile standard.Meanwhile, we discovered another key element in improving overall sound quality that is providing the amplifier with a high current capability. A few premium-priced Class A designs available had previously achieved high current output as available in products of Class A operation. We found from our research and listening experiments that high current itself was actually more significant than Class A operation in determining sound quality. At the same time we became aware of the work of Dr. Matti Otala, a Finnish professor of electrical engineering who demonstrated that ordinary loudspeakers imposed short-term current demands that were not met by existing designs. Dr. Otala’s research confirmed our own findings, and eventually we hired him to assist us in designing a new generation of power amplifiers with power supplies and output stages equal to the task of driving real world loudspeaker loads. The Citation XX, introduced in 1980, was our first high current amplifier. Every subsequent design, including the amplifier sections of our lowest powered AV receivers, has had exceptional current capability in relation to its nominal power rating.In 1987 we introduced our high voltage, high current power amplifiers which utilized new transformer technology to mate the amplifiers optimally to different loudspeaker loads. High current amplifiers impose considerable stress on their own power transformers when forced to operate continuously into low impedance loudspeaker loads. By making the power supply voltage to the output devices switchable, current flow through the outputs is reduced without damping or loss of dynamics. An amplifier with switchable power supply voltage will put the same or greater power into 4 Ohms as into 8 Ohms, and with absolutely no increase in distortion. In our view, it is an extremely sensible way to design a power amplifier.High current capability as a design criterion is only applicable to power amplifiers. CD players, tuners and cassette decks are never required to put out significant amounts of electrical current however, amplifiers are. All Harman Kardon power amplifier circuits, including those in our receivers, are designed to deliver high continuous current in relation to their nominal rated power. To understand the importance of high current, we must examine what an audio power amplifier does in relation to a loudspeaker.
In a physical sense, an amplifier performs work – it does not simply transit information. It provides a source of alternating current for an AC motor that motor being the loudspeaker itself. The fluctuations in current comprise the audio signal. The loudspeaker itself makes physical movements in order to energize the air in the listening space, and the force of those movements is a function of the electrical current presented to the speaker by the amplifier.Wattage, the electrical measurement specified for amplifiers in standard ratings, consists of current times voltage, or Amperes times Volts. Loudspeakers in general, with the exception of the piezo type and electrostatic, are current devices – that is, their output is proportional to current flow through the voice coil circuit, not to voltage. Voltage is only important for overcoming the resistance both of the connecting wire and the voice coil, and for ensuring current flow. Actual current delivery is what really counts.Most solid state amplifiers produced today are more or less constant voltage devices which will maintain constant signal voltage levels in the face of widely varying loudspeaker impedances, and will vary current flow according to the fluctuating impedance at the loudspeaker terminals – but only up to a point. Their ability to do so is determined by their current capability, which in turn is a function of power supply engineering and storage capacity.Interestingly, this fact is ignored in the standardized testing of amplifier power. Amplifiers are typically tested into a stable, precise, 8 Ohm resistor, which doesn’t closely resemble a loudspeaker impedance at all. An 8 Ohm resistor makes very slight demands for current, and with a 40 Volt output working into it, will permit the generation of 100 Watts of power with less than 3 Amperes of current.The problem is that we listen to loudspeakers, not resistors. Loudspeakers are typically inefficient devices with numerous electrical and mechanical reactances in addition to the DC resistance of the voice coil circuit. These reactances alternately interfere with current delivery or short the outputs of the amplifier, thereby making tremendous demands on the power supply. The feedback tells the amplifier to attempt to maintain constant voltage and to make such adjustments in current flow as are necessary to do so.At this point things get interesting. The adjustments in current flow necessary, firstly to overcome the mass of the woofer, the amplifier’s own electrical route to ground, and secondly to deal with momentary impedance nulls may require the amplifier to deliver, on a transient basis, six times the current that is required by a perfectly resistive 8 Ohm load. Producing a 100 Watt output into a nominal 8 Ohm dynamic loudspeaker might very well require an instantaneous current capability of 20 Amperes. An especially reactive 4 Ohm loudspeaker requiring a 200 Watt output could impose current requirements on an amplifier in excess of 50 Amperes.For example, when we designed the Citation XX in 1980, we specified a 100 Ampere peak output as we discovered loudspeakers that would demand this level of current supply at high output levels. Today, even in our entry-level receivers, we engineer current capabilities that far exceed those for competing products.If the amplifier is unable to supply sufficient current, it cannot properly damp a woofer, and is therefore unable to maintain a level frequency response across the audio spectrum. Since a low current amplifier will not be able to maintain constant voltage either, its output waveform will be distorted.Most inexpensive amplifiers are prevented from even trying to supply large amounts of current by protection networks, which limit the underrated output circuits just to keep them from overheating.It is often noted that Harman Kardon’s lowest powered receivers sound more dynamic and powerful than competing units with two or three times the rated power. This is because the competing units commonly have less than half the current capability. As with cubic inches in a car engine, there is no substitute for current capability in an amplifier.
At this point, you may ask why every one else is not delivering high current if it is so important. Manufacturers of limited production, high-end audio amplifiers generally do design their equipment for high current operation, but the manufacturers of mass-produced, moderately-priced equipment often do not. High current capability is a function of power supply design and requires large value capacitors and high power transformers, both of which are bulky and expensive. Even with an adequate power supply, high current cannot easily be achieved with an IC output stage. We choose to put our manufacturing cost in our power supplies and in our signal circuitry, while our competitors prefer to buy circuitry for front panel displays and convenience functions. Life presents us all with choices and Harman Kardon have chosen to build components that sound good, rather than appear ostentatious.As with the design and implementation of wide bandwidth circuits, the use of high current amplifiers is another area where a long-time Harman Kardon philosophy has proven to be more valid than ever in the world of digital audio and multi-channel systems. The system headroom provided by high current amplifiers, and their ability to deal with wide swings in speaker impedance loads and the heavy use of low frequency signals, is critical to the proper playback of movie soundtracks in the home theater setting.The power supply for a consumer audio component has two functions. It changes the alternating current from the wall socket into direct current and it stores that current at a certain predetermined voltage to supply the transistors in the amplification chain. The energy storage capacity of the power supply is basically determined by the operating voltages and electrical capacitance values of the large filter capacitors, which hold the electrical charge. Pricing increases sharply with both voltage rating and capacitance, and this is often an area where other manufacturers may not invest. However, even the smallest Harman Kardon receivers have capacitor banks rated in the tens of thousands of microfarads. Another area where others may be tempted to cut corners is in the power transformer, which charges the capacitors. Transformers are rated in Watts (conventionally expressed as Volt/Amperes) and again, the higher the rating, the higher the cost to the manufacturer. Our least costly receivers have power transformers exceeding 100 Volt/Amperes. Incidentally, large transformers and filter capacitors tend to be heavy which can increase shipping costs.The most costly esoteric amps will have power transformers rated in excess of 1000 Volt/Amperes charging banks of capacitors with cumulative capacitance ratings in the hundreds of thousands of microfarads. There is no question that such supplies represent the preferred approach when final cost is no object. Such a brute force power supply can drive virtually any speaker under most conditions with absolute stability and minimal distortion and the amplifier that possesses such a supply will be able to double power delivery each time the load impedance halves.Harman Kardon and Power for the Digital Revolution are registered trademarks of Harman International Industries, Incorp.
there are so many terms..but generally you can have 2 topologies in Amps where its either aConstant current source or a Constant Voltage source and its very dependent on the speaker
Another area to look in is the Gain of the amp..typically a pre-power combo will be between 27-36dB. these factors have a much larger impact.
But power of an amplifier is very misleading and needs to be taken as an indicatory value only. Iv'e had 20 W amps drive the same speakers in the same room louder/better than 40W amps....
YES, you have Over Simplified the formula.
Power = Voltage x Current read simplistically is only true for DC (Direct Current)
For AC (that includes ALL Music signals), the Voltage & Current are continuously varying. If the current is passing through a speaker, it is not a resistor. Speakers are Very Complex loads, whose impedance varies with frequency & even the cabinet (and to a small extent, on the room.
The speaker Impedance varies WIDELY, ranging from a Resistor at its resonant frequency to a Capacitive and inductive load... all for the same speaker, but a different frequencies....
Just to Add to @IndianEars post on the complexity.
Every piece of music has so many instruments and voices each of them playing across frequencies. If we taken just one of those instruments say a guitar which has fundamental frequencies ranging across say 80 hz to 1K Hz and in a period of just 10 seconds may play at least 4-5 of these frequencies
Even if we take just one of those in an instant of time , say a 200 Hz wave, it will have subharmonics of 100, 50 and 25 hz as well as harmonics of 400, 600 hz andin that instant its that combination that gives it that tone and thats want differentiates one guitar from another guitar not to say a sitar playing at 200hz . now this keeps changing across time at another instant for the duration of the piece for the same instrument
Now imagine that for each instrument /voice in that piece which is also playing at that instant..and now you can extrapolate it to the entire piece. Thats how complex a music signal is and each frequency affects the impedance seen by the amp and they are all changing.
Hence just a word 20W does not convey anything about the amplifier , it will also be about if it can take care of every single frequency at the instant it needs it and a little bit more. Hence many amps represent their static power draw as well as the dynamic draw.
My reading is that high current capability is something needed and worthy.
Can provide a detailed explain if others are interested... (I do not want to derail or dominate this thread, which provides aeroash's perspective).
My revert will be a bit long since the concept of inductive & capacitive impedance needs to be introduced, to understand why high current is essential to properly drive most speakers.
Ideally should be in 2 separate posts, but Mods will telescope into 1 long post :)
I was supposed to follow up on this thread but somehow it skipped my mind.
That is some great info in this thread.
I went though all the material above and these are some of the points that caught my attention
Note that the VA rating does not give you how many volts and how many amps for the transformer, it gives the combination of the two. For example: If I have a 400VA transformer I could have a transformer that is rated at 40 volts and 10 amps or I could have a transformer rated at 80 volts and 5 amps. The VA rating is the same for both!
generally you can have 2 typologies in Amps where its either constant current source or a Constant Voltage source and its very dependent on the speaker
So even though the power is proportional to current, the other factors like the voltage, speaker impedance, and the protection circuits will have its impact.
Great Summary, sudokpr
I agree with all except the last one, ie:
"generally you can have 2 typologies in Amps where its either constant current source or a Constant Voltage source and its very dependent on the speaker"
