LG C2 65inch Left side Pink tint after 4 months usage.
nitz_vision
Hello,
Unfortunately i see pink tint/bleed on my LG C2 65inch tv on the left side. Other people please comment if anyone has issue and how it was corrected? Does it effect viewing? also over the time will it messup more? Should i ask for tv replace as its 5 months old and its under insurance and warrenty for 3 years.? I am big LG fan did i miss buying sonys or samsungs?
TIA
Apparently its a common issue on LG OLEDs. How severe is it? Do you notice it in normal content?
If it is quite noticeable, get it replaced.
For context, the RTINGS review of this TV also had it : (Scroll down to Gray Uniformity )
In my LG C10, it is not observed even after 2 years and 4 months of usage. Maybe Evo panels have that commonality.
Adding few more images. Please suggest next steps?
Hello,
TIA
Did you contact lg service? What did they say?
MaSh
MaSh
Contacted they will come shortly. India customers won't get justice easily. So wanted expertise to tackle this issue. I wish they give replacement. Can't expect 1.8L tv going for toss in 4 months.
Oh okay good. Go with an open mind and see what they advice. Replacement or even repair under warranty, as long as you have a tv in perfect working condition.
MaSh
MaSh
Initialy in technician said angle issue. I asked why this was not their during installation? why after 4 month?. Why its seen when sat on center too.? Then he accepted the probelm and checking more with technical team.
Adding angle photos. See from right corner full pink on left.20230803_131148.jpg20230803_131148.jpg
See from left corner no pink at all in right.
Engineer accepted the problem.. I want tv replacement as its 4 months old.. they are doing panel replace.. please suggest?
10,000+ hrs (2 years) clocked on my Evo panel and no burn in/ discoloration, despite using it primarily as a PC monitor with plenty of static elements😁
Its a pink taint diagonally observed by OP. They replaced the panel. But first they were in denial nothing big happened.
