Back to tubes
The 8's are 87db with 6.4 ohms minimum, so need a stouter amp. I may try a push pull down the road, but for now I am looking forward to one my favored amplification schemes, i.e; tube preamp into class d, namely hypex based amps. Will be experimenting with that soon.
I am a bit reluctant now-a-days with tube/integrated and amps. due to the heat factor plus the ongoing power tube maintenance, with the lack of a proper tube vendor in India etc.
Sid
Thanks for sharing. I have read good things about the hypex based amps, especially from Nord and Kjf of UK. But ive been reliably told that the newer purifi eigentakt designs are a step above the previous hypex and ice based amps. Maybe something you might want to consider.
And I completely agree about tube heat and the scarcity of reliable new tubes in India. I had to buy tubes directly from the manufacturer at jacked up prices, and in the other instance where I bought from amazon, 2 tubes were dead on arrival. And have received similar new tubes in non working condition from local vendors in the past too.
Besides, yeah 87db and 6.4 ohms definitely calls for a stout amp :)
I am going to try a basic Hypex nc 252 amp first. For me the synergy with a tube pre. amp. is the critical criteria. In the past when I paired an Ayon DAC/pre with a nuprime ST10, I was bowled over, and have been pining for that type of a signature since then. I tried a very low cost Chinese amp. recently but wasn't too satisfied so going to the entry level hypex. If this works out then I will go the whole hog with mono blocks, buffers etc etc.
Sid
Sid
Makes complete sense....all the best :)
If the tube vendor doesn't have a tube tester with published results then I prefer to stay away. There is no way they can perform matching or even predict the tube quality/strength etc. Afaik, no Indian vendor has this capability other than buying from the mfr. and selling at inflated pricing (not that it is a big deal, but requires some commitment on the part of the vendor).
Hence I buy either new or NOS from Tube Depot or the tube store. However buying multiple power tubes can get get expensive plus the hassle of getting them here, either on our own trips or requesting someone etc etc. So I am trying to avoid all this, however I am still open. Down the road maybe will consider it. Right now I still have 2 tube pre-amps and 1 tube dac with some 12 tubes overall, fortunately these are preamp tubes so they last a lot longer.
Sid
Sid
I got a VTV Hypex Ncore 252Mp amp recently, based on my above experience of tube pre's into class D amps. Wow! This pairing (with the AP swara V2) at significant discount to my previous experience (perhaps at 1/3 the price) sounds superb. The control that the little VTV is exhibiting on the mofi 8's woofers is amazing, much, much better than the O&B amp. Overall the sound quality has improved significantly. Very satisfied with this.
Sid
To be fair to O&B, I would assume, I would have to step up to their higher offerings - which would be an even comparison to the VTV. The VTV costs about 25% higher.
Sid
Past few weeks, I have been driving my Sabrinas with the tiny vtv - hypex nc252 mp. I was a bit hesitant at first - the Wilsons, are fairly difficult loads, dipping to 3 ohms, but my fears were unfounded. This little inexpensive amp. is driving them superbly. On the whole I have been inspired tremendously with the new breed of Class D amplifiers. I am planning to get a purifi version to see if it sounds better.
Sid
I have been experimenting with the so called switching amplifiers off and on since about 2009 starting with the Belcanto s300, another belcanto s500, 2 nuprimes and finally the hypex Nc252mp. While the initial belcanto s300 was sterile and cold prompting me to sell it in 6 months, every subsequent iteration since then has become better and better. Right now I think the technology has matured very well indeed, with the current purifi based Nad M23 being hailed as the perfect amplifier.
Exciting times, for me at-least.
Sid
Sid
True, Class D has matured quite sometime back and many companies are implementing. The 12 colt industry (car audio) was the first to garner the potential of Class D amplification primairly because of the advantage of shrinkage of size/space and dramatic increase in efficiency. It started with monoblocks to drive the subs and soon was implemented in the stereo amps as well. As early as 2015 there was some very good sounding Class D amps in car audio from some German and Italian companies.
Sid
I have heard the M33 which uses the same circuitry. It was absolutely fantastic to listen to. It changed my outlook towards Class D. I no longer treat them with contempt.
Recently upgraded to a Sony VPL - XW 5000 laser projector. I am quite impressed with the picture - the extra brightness compared my previous 270es has really kicked up the HDR images, seeing more pop and I also feel resolution is also much better due to the use of their X1 processor. Some downsides as well that I miss from the 270es - no motorized lens control - all focusing etc has to be done manually, secondly I think overall build quality has been downgraded in these newer entry level Sony models though they are more expensive now - undoubtedly to accommodate laser technology etc. However at the end of the day, personally for me, the PQ more than makes up for these shortcomings.
Sid
For FM's who have the Sony 5000es projector and want to calibrate it (albeit on their own), I used these settings from projector central:
These settings work very well, especially the HDR ones.
Although I reduced the laser output setting to 50%, the picture is still plenty bright plus the fan noise is almost silent, thought I sit right under the unit.
Sid
Sid
Thanks a lot for sharing!
I was looking for upgrade in Epson lineup earlier, but this Looks like a decent upgrade from Epson 9400 HDR compatible Projector, Will start Saving 😅.
What other Laser Projectors you considered before zeroing on This Sony Model? Did you audition any?
I'm also looking for a possible acquisition, maybe a projector or a speaker. What projectors did you demo/see before deciding? Did you see any DLP?
There's the EH-LS12000B from the Epson stable.
Seems to have very good reviews.
