My DIY Enclosures - Common Thread for all my Enclosures
Sadik has done an awesome job with these waveguides.. :)
Here is a pic of the waveguide resting on top of a cabinet housing 2 x Satori WO24P 9.5inch woofers (just for scale)..
Lovely build of those gorgeous looking wave guides. Dont mean to hijack the thread...but can you please elaborate a bit on these horns. The frequency range, efficiency and compression driver used etc. Not everyday that we get to see horns around here :)
Thanks.. :)
These are the EXAR 400 horns from Marcel Batik (mabat on diyaudio). It accommodates 1inch compression drivers
The frequency range can probably be anywhere from 800Hz to 20kHz depending upon the system configuration.
Here are my polar measurements of a 1-inch BMS 4550 on this horn (raw responses)
My plan is to also try out this horn with the SB Audience Rosso 65 1.4inch CD with a custom 1inch adaptor designed by mabat.
Measurements taken 1m away from horn mouth (gated at 4.1ms)
On axis frequency response and impedance measurement together
VituixCAD plots
Normalized directivity computed with reference axis as 10 degrees off axis
Here is what a rough active filtering on this horn can do
And here is a rough first-cut passive filter
Thanks.. :)
VituixCAD plots
Thanks for sharing...the measurements look sweet. And a wide range of 800 to 20k is excellent to have without any crossovers in between. All the best to trying out the CD with the throat adapter.
Due to health issues (lower Back Pain) i am a bit slower on my builds, I have a total of 4 Projects which were yet to be completed, I really appreciate the patience of my clients who had given me the opportunity to make their enclosures, They have given me lot of time to complete their enclosures. I didn't touched a single tool or a piece of wood for about a month. And i have decided to take a break after completing all the 4 Projects. 1 of them is completed which are small Bookshelf enclosures and there are 3 more pending. Here are some Photos of same.
IMG-20240814-WA0010.jpgIMG-20240814-WA0011.jpgIMG-20240814-WA0014.jpgIMG-20240814-WA0019.jpgIMG-20240814-WA0025.jpg
Earlier it was decided to color the enclosure completely, but the grains of Birch wood turned out so nice that client insisted for a dark stained Rosewood polish, and top coat is clear Matt PU paint.
Take care and get well soon and come back all hale and hearty. wishing you the very best !
Dear Sadik, I hope that you feel better now. Don't worry, you will do many outstanding masterpices by your artistry. God Bless You. Regards.
Sunder.
Hi Friends, Now a days I am not very active on hifivision, In fact I am not getting enough time to document my built journey so I thought of at least make a thread where I can share the photos of the complete enclosures. So from now on I will be posting photos of all my enclosure projects in this thread.
So the First post in this thread are custom designed enclosures, they are huge with external dimensions as 1280 (H) x 380 (W) x 420 (D)
These enclosures are RAW finish. (No Veneer, No Putty work, no Primer no Sealer no clear just RAW enclosures and Shellac Polish). One of my hardest project till date because I had to take great precautions during cutting and assembling them. The DIY guys may be very well aware of cutting plywood in the opposite grains, The Plywood gets chip off while cutting along opposite grains of wood. A slight chip off will ruin the complete look of enclosures.
Lets enjoy some final built photos of enclosures
View attachment 82262View attachment 82263View attachment 82264View attachment 82265View attachment 82266View attachment 82267View attachment 82268View attachment 82269View attachment 82270View attachment 82271
While taking up this project i had discussed with user and made it clear about all the difficulties which may occur in the enclosures, (like chipping of plywood while cutting in opposite grains of wood, some air pockets in the internal of plywood after cutting, or may it be some dents on surface of plywood etc) he also understood the same and gave me green signal to go ahead and make the project happen. Secondly making grill is not my cup of tea but still i manage to make a good looking grill and for such a huge enclosure the grill was also another task.
But in the End this Project turn out to be a Master Piece. Next Project is soon on the way... Stay tuned.
Superb ...Very nice
