How to play 3d ripped movies (mkv or iso) in windows with a 3d Projector?
buzzaro
Ahmedabad
I have a 3d Projector Benq TK850i and DLP-Link 3d glasses that supports it.
Also have Media Players - Kodi on Firestick 4k and Potplayer on Windows11 Ryzen PC with Nvidia 3060 GPU
I have ripped 3d movies in Half SBS format in mkv container and also a full remux in ISO container. I tried playing them in both Kodi firestick and Potplayer in windows11 but it always shows in side-by-side dual screen and not overlapped single screen that can be viewed through 3d glasses.
What am I missing? I tried googling and searching through other forum posts but most results are either too old and outdated or not working for me. If anyone has any experience playing 3d content on their DLP projector, any advice is appreciated. Thanks.
Did you try with a 3D demo reel or something like that? If you're getting that in 3D, the problem should be in your source material.
I don't have 3D in my projector but I have watched projected 3D played by Pot player. IIRC two settings need to checked. In Video menu >> 3D, "3D mode" set to "side-by-side" and then 3D playback must be enabled in Advanced options. Tryout these options.
Cannot comment on Kodi, but there must be some plugins.
As others said, need to turn on 3D mode in projector. Also in plot player there is a setting which need to change for 3D.
In kodi player there's a option to switch 3d mode of your movie. Change to the mode which your projector support
The video might help
You’re not doing anything wrong, the projector just isn’t switching into its 3D mode automatically. Half-SBS files always display as two side-by-side images until the projector is told to convert them into 3D.
Go into your BenQ TK850i menu and manually set 3D → Side-by-Side (SBS). Once that’s enabled, the projector will merge the two images and your DLP-Link glasses will sync normally.
ISO/full 3D won’t trigger auto-3D either unless you’re using a dedicated 3D Blu-ray player, so manually selecting SBS is the easiest fix.
For all 3D enthusiasts,
There are very limited options to play 3D ISO files.
1. Buy a dedicated media player that supports 3D MVC/ISO playback. ( Ex-Zidoo Z9X Pro). Price 30k in India, 18k in US
Dune stopped 3d support. You need to buy a old player.
2. Custom Raspberry Pi 3B+ box with libreELEC 8.2.5(old Kodi). Process is tedious but works. It sends frame packing signal to your projector but remember no lossless audio support(DTS HD, Dolby True HD)
Price approx 6500/-
HTPC is not recommended because MS Windows, Intel , AMD, Nvidia, Kodi, PowerDVD all stopped 3D support.
Price approx 6500/-
PowerDVD ultra in the PC supports 3D playback from bluray or iso file (needs additional driver though). Their subscription cost is expensive. None of the other player supports 3D playback from blueray disc/or iso file. KODI supports playback only with 2D with iso mounted to disk.
KODI / MPC+madVR / Stereoscopic players supports clean 3D playback from mkv files. I tried them it's good.
The 3D depth is not that great , the objects are not popping in front of your eyes , the 3D effect is contained within the screen.
But still it's different experience to watch movies with 3D. I watched Prometeus , Transformers , Jurrassic park Lost world ..etc. .
Experience is far better than watching in 2D.
3D limitations are within this technology i guess. Another problem with active shutter glass is - it misses sync in between and loosing 3D effect either you need to power reset shutter glasses - or u need to reset 3D mode in Projector.
I don't think PowerDVD latest versions support 3D.
Even kodi stopped. I have old Kodi version(LibreElec 8.2) installed in RPi 3B+. if you want to experience true frame packing 3D, this is the best DIY method.
MPC+madVR setup is good for SBS/TAB formats. It can't play frame packed(ISO/MVC).
yes, PowerDVD latest version does not support. their older version supports 3D blueray playback but tough to get older version.
@ItsBabu how is your over all experience of 3D viewing with Active shutter glass with projector ?. The 3D effect is good but not immersive. The 3D effect is contained within the screen and objects not popping in front of our eyes as we see in some 3D cinema theaters.
3D experience in my Benq W4100i projector is really good. 3D is another reason to choose the projector. It's got enough brightness though the shutter glasses( from Benq) block lot of light.
you are right about screen quality plays an important role for 3D experience. When I had a demo of my projector, I really had a good experience but it's not that good on my old Elite manual pull screen. So planning to upgrade to tab tension screen(Grandview/Elite Cinewhite) to leverage 4K HDR and 3D capabilities of my projector.
With a proper screen(Flat with less texture), dark room and a decent sound system, we can almost get a theatre(not IMAX :)) like immersive experience with a good quality 3D projectors.
