Preamp upgrade from AMR DP 777
reignofchaos
So here is the deal - I have been looking for a standalone preamp and have been completely unsuccessful in finding a better one than the inbuilt analog volume control in my AMR DP 777 DAC. I use this - even my EAR phono preamp feeds into the analog section of this DAC.
Have tried the following and have come back to the internal preamp:
Audio research LS26/Ref6
BAT VK33SE
Jeff Rowland Coherence 2
Acoustic Portrait Thiyaga
Pass XP12
McCormack RLD-1
What do I really look at? Has anyone upgraded from the internal preamp of this dac without spending megabucks? I am completely lost now and am thinking of stopping my search.
Ok. That’s surprising. It’s a very good pre. Doesn’t sound bloated. Maybe it had no synergy with the equipment you had.
Quite possible! However it wasn't the quietest unit either. That kind of made me discount it more than anything. Everything else in the chain is absolutely dead quiet inspite of it being tube.
It’s normally nice to get a pre of the same brand as the power or the phono. IME too much mix n match causes a lot of issues.
If you are not looking for gain, EMIA autoformer by Dave Slagle or Music First are good.
I don’t know which model I heard, but it was dead quiet. Also fairly neutral. What I heard was definitely not bloated and played dead quiet. The problems you were hearing could have been because of a bad tube.
But I can understand once you have had such an experience with a brand, you definitely don’t want to look at it.
Mod's note:
Multiple back to back messages are merged in a single post to prevent clutter.
Have you tried the simple Micro Zotl which Arjun uses. It’s a quiet, fast, dynamic, transparent pre.
You don’t need the full sized pre. The micro Zotl is good enough. You just need to figure if it works in your system. Chances are it will since Arjun also uses a higher end Tannoy and amp with KT 88 tubes
Please check these too.
Silvercore Preamp 324 from Germany. No longer made but check with the owner of the company or keep an eye on the used market. There was one available recently but gone now.
If you can manage DIY, https://intactaudio.com/atten.html
If you like passives, it will be nearly impossible for you to go back.
Intact Audio is the same as EMIA. They are both owned by Slagle. I had used the Intact Audio autoformer vol control and requested Viren to incorporate into the amp. I am a fan of Slagle’s stuff
Silvercore usually uses silver winding in all his stuff. I would probably not go down the silver route for Tannoys.
My current preamp is a passive resistor ladder attenuator + tube buffer for impedance matching. So in a way, I do know what a passive sounds like.
I have had some knowns around coming with silver/copper argument and I lent them my Silvercore preamp 324 to try to change their opinion. It is hard for me to deny the transparency silver offers compared to copper. I have compared mine with Music First copper based and found that MF narrows the soundstage.
Unfortunately, when I was in market, Slagle did not have the silver version of his autoformer but now he has and has it for a reason.
Which one is it? Asking because if I get an opportunity, can compare it with Silvercore and share the experience here.
I forgot to mention that this company used Slagle's transformers at one point in time but not sure what they use now. But it is better to check.
Since this is an interesting topic, what expectations do you have from this new preamplifier, @reignofchaos?
You havnt mentioned the amp with which you paired the above pre amps with or the amp you currently intend to pair with.
It should not matter but here they are:
Audio Space EL34 monos (Nova M34)
Rogue Audio Stereo 100 (Dual KT88)
A Modwright LS100 is coming for trial later this week. It is a rather simple preamp with good parts. Hoping that it works.
Have a considered a Rogue preamp itself ? It should suit the Rogue 100.
Or a Lamm pre if you can get one.
